Interior/Exterior Antenna base removal-HOW!???
Old Nov 11, 2005 | 08:51 PM
Kentiki's Avatar
Kentiki
I promise, I've searched on this topic, but could not find the answer. On my 05 MCS, how the heck do I get the antenna base off? I have to put some roof graphics on, and the base will not budge!
Old Nov 11, 2005 | 09:05 PM
Nuff's Avatar
Nuff
I think there is a bolt holding the antenna base in place. I've heard that to get to it, you need to remove the c-pillar cover and pull back the headliner. I haven't tried it myself, but I'm sure some other NAMer has.
Good luck.
Old Nov 11, 2005 | 09:10 PM
namwob's Avatar
namwob
On the 02-04 you rotate the cover counterclockwise, according to the Bently Bible, to expose the retaining nut for the base. Carefully pull down the rear of the headliner with the rear hatch open to remove base (be careful not to crease the headliner)
Old Nov 11, 2005 | 09:27 PM
thefuturequeenofnebraska's Avatar
ask ryephile or agokart.... they did mine... good luck!
Old Nov 11, 2005 | 10:03 PM
ebock's Avatar
ebock
Inside the rear of the car (on the headloiner), you will see a plastic cover (this is where the motion sensor for the alarm goes). If you remove this cover, you can see the retaining bolt for the antenna. I used a socket with a swivel joint to loosen this. (I had to do this to switch to the sattelite radio antenna)
Old Nov 12, 2005 | 07:57 AM
Kentiki's Avatar
Kentiki
Thanks everyone! I'm gonna do this today and will report back. On my 02, I could remove the base with a simple twist! Oh well, I'm about to get even more intimate with the 05.
Ken
Old Nov 14, 2005 | 07:59 AM
Kentiki's Avatar
Kentiki
Update: I did have to remove the headliner partially. I was then able (barely) to unscrew the retaining nut and remove the antenna base. There are 2 wires that also need to be unplugged. A PITA, but not too bad.
Ken
patsum
26
May 29, 2021 06:29 PM
Bennyboy
Dec 1, 2016 11:09 AM
Accessory Products
Sep 9, 2015 10:29 AM
kjd186
Sep 9, 2015 10:02 AM
schwac2
Sep 3, 2015 08:56 PM
