Interior/Exterior are there any white or clear back lights for 2005 S's?
Old May 10, 2005 | 12:47 PM
upsilon23's Avatar
upsilon23
like the euro stuff, I love the way it looks on a black MINI which is what I'll have in 2 days!!!!! There's plenty on ebay but they're all for 2004-2002, none for 2005's. Help a soon to be new MINI Coop S driver out!! thanks
Old May 10, 2005 | 02:29 PM
regalic's Avatar
regalic
if you install a 02-04 reverse light on your 05 MINI you can then install a 02-04 white light kit.
Only thing you would have to do is route the wire in the 1 slot on the rear tail light plug to your new reverse light and then route your rear fog light wire to both of the rear tail lights in the #1 slot on your rear tail lights.
After that you can do the diode mod (connect a diode from slot 4 to 1) so that the top light comes on while braking. This should give you all the same functionality as a factor installed white light kit.
Also you would need 2 red reflectors installed to be street legal. Easiest place is on your 2 black plastic pieces in the rear bumper. Or you can have your dealership install them in the bumper but this requires them to drill your bumper.
Old May 10, 2005 | 02:56 PM
upsilon23's Avatar
upsilon23
thanks, sound like probably more work than I hoped. so I'm guessing that there isn't a new one out that's a direct replacement, any idea if there will be in the next couple of months?
Old May 10, 2005 | 03:16 PM
NeilM's Avatar
NeilM
Yes, there's a factory clear Euro rear light cluster for the '05. As far as I know there's nobody importing this yet, but you can order from <http://www.newministuff.com/new/index.php> in the UK.
As a plus the turn signals light up amber, instead of the lame red we get.
Neil
05 MCS
Sexual Chocolate
Mar 31, 2019 08:02 PM
Dec 23, 2015 10:36 AM
mdutton11
14
Oct 26, 2015 01:47 PM
OutMotoring
Aug 6, 2015 09:32 AM
nismo4life
Aug 5, 2015 08:31 AM
