Interior/Exterior decal installation tempurature
Old Feb 26, 2005 | 02:34 PM
laxpimp6903's Avatar
laxpimp6903
i recently ordered a set of bonnet stripes to install on my mini and i recieved them today and am excited to put them on but i am worried about the temperature because it is only about 32 degrees. is there a specific temperature that they need to be installed at to be sure they will adhere properly
Old Feb 26, 2005 | 03:43 PM
eurazn's Avatar
eurazn
I would not recommend you do this in the cold weather. 50F and above is recommended. Use hairblower to remove air bubbles. Make sure use a bowl of water with several drops of soap. Please post pics after you completed
Old Feb 26, 2005 | 06:15 PM
laxpimp6903
thanks for the help. my neighbor actually has a headed garage and offered to let me use it for the day so i didnt have to wait another month or so to install them. i plan on installing them tomarrow. will be sure to post pics if i can figure out how.
Old Feb 27, 2005 | 05:30 AM
BrewSwapGuy's Avatar
BrewSwapGuy
Formerly PassatDoTd
Be sure to let your car's body warm up in the garage of use a hair dryer to warm it up. After installing leave it in the heated garage for 3 hours for it to adhere properly.
Old Feb 27, 2005 | 06:18 AM
kenchan's Avatar
kenchan
I use above 70F. In the winter time, I use heat lamps (2 of them)
to heat up the bonnet before application (warm to the touch), then let
them toast (kind of hot, not super hot to the touch) a few hours for
proper adhesion. :smile:
Old Feb 27, 2005 | 07:50 AM
laxpimp6903
Thank You everyone for your help i will let you know how they turn out
Old Feb 27, 2005 | 02:43 PM
laxpimp6903
the stripes have been installed and i will post pictures shortly. the stripes look great but i am slightly upset that they were not quite long enough and now there are reasonably large spaces at the top and bottom of the decals where they should be lining up witht he grille and top of the hood there is about half inch gap at the top and at the bottom. has anyone else had this problem
Old Feb 27, 2005 | 03:41 PM
kenchan's Avatar
kenchan
Its shorter on mine too...so I aligned it to the grill since people will notice
it more than the top of the bonnet. Mine was about 1/4" shorter both times.
Old Feb 28, 2005 | 06:32 PM
laxpimp6903
The final product
Old Mar 1, 2005 | 11:05 AM
kenchan's Avatar
kenchan
Looks sharp!
Old Mar 3, 2005 | 08:46 AM
mariog's Avatar
mariog
Bonnet stripes
My guess is that you ordered the wrong stripes and ended up with the ones for the non-S model. The ones for the S are a little bit longer to cover the additional hood area that the scoop bulge creates.
(Don't worry, nobody is going to know though...)
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
