Electrical Turn on High Beam and lost low beam.
Old Apr 6, 2023 | 07:06 AM
karenjackson's Avatar
karenjackson
Can help me with a somewhat silly question?
I have an intention to upgrade my headlights. I bought an H4 holder, connected the H4 bulb to it, and then installed it on my car. According to my understanding, the Halogen (base) has the following pin configuration:
-Power on Pin 3
-Ground on Pin 4
-High Beam on Pin 6
-Turn Signal on Pin 12
Everything seemed fine until I turned on the high beam. Whenever I turn on the high beam, the low beam goes off.
It seems that your original halogen headlights are working normally, and you are able to turn on both the
I wonder if there is any circuitry inside the stock headlights?
Old Apr 6, 2023 | 08:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What car do you have? Stock halogen bulbs should be H13, not H4... That being said, the low beams should turn off when you switch to high beams, that's the way its designed.
Old Apr 6, 2023 | 08:43 AM
karenjackson
My car is a 2008 (S) Mini R56, and I'm wondering why when I turn on the high beams, the stock lights remain on as well. I don't quite understand it. My car uses H4 bulbs
Old Apr 6, 2023 | 09:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
You might have to post up some pictures of your specific car. Sounds like a conversion was performed at some point, either aftermarket headlights or something else.
dcwang3
Jan 25, 2020 10:00 AM
Smitha6
Mar 1, 2016 11:07 AM
smokeysevin
Electrical
Mar 16, 2014 01:02 AM
NoFe2O3
Jul 7, 2005 06:54 PM
Servoman
Sep 17, 2002 02:32 PM
