Interior/Exterior Door trim removal
Old Jan 12, 2022 | 05:35 PM
RIPPER's Avatar
RIPPER
Door trim removal
can the painted door trim that matches the dash trim be removed from the door panels so they can be wrapped or painted ?
Old Jan 12, 2022 | 06:44 PM
RB-MINI's Avatar
RB-MINI
The trim is “riveted” on the door panels. The pieces have plastic posts which go through holes in the door panels, then the ends of the posts are melted and mushroomed over to secure them. All of the posts I’ve seen end with glueing or siliconingthe trim back on.
Not sure how secure or messy that would be so I’m going to try and remove the mushroom head, then drill a small hole in the post and use truss head screws to re-install the trim.
Old Jan 15, 2022 | 07:31 PM
RIPPER's Avatar
RIPPER
please post pics when done.
Old Jan 15, 2022 | 07:52 PM
MCS4FUN's Avatar
MCS4FUN
Rather than "riveted", the correct terminology would be "heat staked". Nonetheless, same removal method would need to be used to remove those trim pieces. My own driver card/panel had an impression dent which otherwise detracted from as-new condition, so I spent significant $$ for a new OEM replacement. Doing that included the correct trim pieces within P/N per VIN (Anthracite in my case), however does not include the speaker grille which differs in P/N whether standard audio as mine or optional H/K with that grilled subsequently needing to be purchased and installed in the new panel. Pics below show backside of card/panel with heat-staked spots on the old and through holes on the replacement where the grille installs. BTW, my original card/panel remains available in NAM classifieds for anyone looking.
Kyriakos
Jan 4, 2016 07:53 AM
oldkid6
May 23, 2015 09:25 AM
oldkid6
May 16, 2015 07:30 PM
blkkouki
May 15, 2008 09:22 AM
pimpedout97x
May 21, 2007 11:11 AM
