Interior/Exterior Firewall plastic removal
Old Nov 23, 2021 | 03:22 PM
Mereco's Avatar
Mereco
My firewall plastic has broken has anyone removed it and has pictures .
tia
Old Nov 23, 2021 | 09:17 PM
BlwnAway's Avatar
BlwnAway
tia
I first cut mine, then removed it completely.
It's been a while, but if I remember it wasn't difficult, just time consuming (if the engine is in, I did mine with the engine out.)
If it's not a total loss, I'd try Plastic Epoxy (weld) first. If I remember correctly, the drivers side is tight, and P/S reservoir and coolant reservoir have to be disconnected + CAI removed.
Old Nov 23, 2021 | 11:14 PM
RB-MINI's Avatar
RB-MINI
It might not too bad depending on where it’s cracked as it’s three separate pieces. You can see the breakdown of the pieces and fasteners here:
https://www.realoem.com/bmw/enUS/sho...diagId=51_4364
I think it only took about 20 minutes to replace the drivers side when replacing with the JCW airbox panel.
Old Nov 30, 2021 | 03:33 PM
r53racer's Avatar
r53racer
It's been a while, .
Curious, Did you ever put it back on? or did you leave it out?
Old Nov 30, 2021 | 08:26 PM
BlwnAway's Avatar
BlwnAway
No, it's out permanently for clearance.
​​​​​​My setup requires the room for the exhaust manifold turbo and down pipe.
It is absolutely needed for creature comfort in the car, I get inside windshield fogging when the car isn't ruining, and more engine compartment smells when idling. It being there and sealing properly to the bonnet, is a vital part for fresh air in the cabin.
chocobo_ff
Navigation and Audio
Jun 1, 2017 02:17 PM
Motor On
Jul 31, 2009 02:06 PM
e_rkk
Jan 18, 2008 10:00 PM
