Interior/Exterior Pedal modifications, anyone?
Old Nov 9, 2004 | 07:36 PM
Crabtree's Avatar
Crabtree
Having a bit of an issue heel and toeing and find that a bit of an extension of the accellerator pedal would help. I see that Razo has a set of pedals that have an adjustment for both the gas and brake, allowing an additional 1/2 inch or so of pedal extension.
Anybody install aftermarket pedals yet? Any issues? Compatible with the electronic throttle, etc? All advice/insights welcome! Thanks!
Old Nov 9, 2004 | 07:39 PM
kyriian's Avatar
kyriian
ive searched for too long for aftermarket pedals for the rubber ones i have now.. the conclusion is that you'd need modifications for most, if not all aftermarket pedals to install properly on the mini, i've been trying to fit a set of MOMO lemans, but failed due to the bolt are way too out to install on the current setup
i believe moss has a set of aftermarket pedals with an heel-and-toe extension
Old Nov 9, 2004 | 09:28 PM
kenchan's Avatar
kenchan
crabtree- Just do the cheater-style heel and toe on these cars. Use the ball of your right foot on the brake and pinky on the accelerator.
You should not have to buy aftermarket pedals to heel&toe on this car.
Old Nov 10, 2004 | 04:30 AM
onasled's Avatar
onasled
Just fit a set of Sparcos ....
Old Nov 10, 2004 | 05:13 AM
MSFITOY's Avatar
MSFITOY
Try making your own Aluminum's cheap.
Old Nov 10, 2004 | 01:24 PM
Moorlockx's Avatar
Moorlockx
>>>You should not have to buy aftermarket pedals to heel&toe on this car.<<
Depends on how wide your feet are. I couldn't do it with the stock pedals. I had to add these:
drrigg
May 27, 2022 03:31 AM
Doc Pain
Mar 10, 2021 04:50 AM
scfiveo
Sep 27, 2019 02:27 PM
vulkandino
Oct 31, 2015 08:29 PM
point665
Sep 29, 2015 12:41 PM
