Interior/Exterior Grille Nuts
Old Nov 9, 2004 | 08:00 AM
770 KOF's Avatar
770 KOF
Grille Nuts
I fitted the aero grille to my MCS and in the process of installing the upper grille I lost some of the 10mm nuts into the abyss of the engine bay. Anyone know where I can get replacements?
Alan
Old Nov 9, 2004 | 08:12 AM
Smokey's Avatar
Smokey
Originally Posted by 770 KOF
Grille Nuts
God that sounds like it would hurt !
Alan
They should be available at just about any parts store (Auto Zone, Advance etc.) Pretty much a standard type item, I've always seen them in the "Help" product isle. You might even want to check with the Home stores in their specialty fastener section.
By the way they are called Hex Pal Nuts. Good Luck!
Old Nov 9, 2004 | 08:18 AM
Ryephile's Avatar
Ryephile
yea common problem with grilles that've been re-worked. A rather yukkie fastening method, imo.
Good luck finding your nuts!
Old Nov 9, 2004 | 09:33 AM
JoeDentist's Avatar
JoeDentist
A 10 mm bolt is pretty big - I'm betting that what you mean is that the wrench size you use is a 10 mm wrench. The actual nut "size" may be a 6mm 1.5 pitch. Take one of the bolts or machine screws with you, match the size and thread pitch, get stainless steel self-locking nuts and do it once.
Old Nov 9, 2004 | 10:46 AM
kenchan's Avatar
kenchan
Ace Hardware carries a lot of different metric nuts and bolts (loose, so
you can buy even just 1pc).
Alan
Old Nov 9, 2004 | 04:13 PM
bodinski's Avatar
bodinski
I've seen them in my local Lowe's Hardware store. They're in a drawer with other specialty type fasteners.
Best - Bodinski
Old Nov 10, 2004 | 01:33 PM
770 KOF's Avatar
770 KOF
Thanks guys - will check out Lowes first. I feel really lost without my nuts
Alan (nutless in North Carolina)
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
vetsvette
Oct 11, 2015 06:05 PM
krohm
Sep 28, 2015 12:16 PM
BendersMINI
Sep 27, 2015 07:02 PM
