Interior/Exterior Pre Facelift Heated Seats on Facelift R53
Old Mar 16, 2018 | 06:33 AM
minicooperlover22's Avatar
minicooperlover22
I am looking to install the heated seats into my 2005 Facelift R53, I found a set of seats from a 2002 that are heated. I was told that this may set an airbag light because there isn't an airbag in the seat on the pre-facelift R53's. I know that I have to get the retrofit kit in order to install them.
Old Mar 16, 2018 | 06:39 AM
ItsmeWayne's Avatar
ItsmeWayne
why not just try to find a newer set of heated seats? There are many out there!
Old Mar 16, 2018 | 06:53 AM
BRGPA's Avatar
BRGPA
Are you certain that a 2002 S doesn't have airbags in the seats? My '03 was built in August of 2002 and has tags on the seats indicating airbags. As I recall there are a total of six airbags- two in the dash, two in the front seats, and two curtain airbags. I don't think any of that changed between the 2002 and 2003 models.
Old Mar 16, 2018 | 01:12 PM
Whine not Walnuts's Avatar
Whine not Walnuts
You can check parts very easy by going to RealOEM. Be sure to have the month that the car was built. By comparing part numbers you will know if you can change without a whole lot of messing around.
And going to move this to the Mod - Interior/Exterior
Old Mar 17, 2018 | 11:22 AM
Noonzio's Avatar
Noonzio
There's a sensor in the facelift seats that isn't in the pre-facelift seats. So yes, you will have an airbag (SRS) warning light on unless you code it out
Smitha6
Electrical
May 8, 2017 06:49 AM
Manny_cooper
35
Dec 9, 2014 09:13 AM
Prost
R55 :: Clubman Talk (2008+)
Jan 7, 2011 11:27 AM
fensty245
Nov 12, 2010 08:39 AM
