Interior/Exterior H7 LED Bulb clearance issues
Old Oct 30, 2017 | 12:27 PM
chairmanmau's Avatar
chairmanmau
Hey there folks. Hope that Monday grind is treating you well!
I went a different route with lighting and decided to go with an LED conversion kit off Amazon -- pretty well-rated and seems to be legit.
I received it a couple weeks ago and tried to install, but I seem to be having some clearance issues -- seems like the "bulb" itself hitting the reflector, not allowing me to secure the bulb in place. I have 2002 halogen housings.
Has anyone encountered the same issue or can someone with the know-how shed some light on this? Picture of bulb attached.
Old Oct 30, 2017 | 03:47 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Mod section. Have you checked RealOEM to see if the headlights are the same on the early to later models?
Old Oct 30, 2017 | 11:02 PM
chairmanmau
Parts are exchangeable according to RealOEM -- am I missing something here?
Old Nov 3, 2017 | 04:49 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Hold up the OEM bulb next to the LED one purchased...how much longer is it ?
Old Nov 10, 2017 | 02:48 PM
-=gRaY rAvEn=-
Moderator
Old Nov 10, 2017 | 03:12 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
If you believe them. This kind of problems is very common with LED "upgrades".
I personally don't see the point. Despite the touted efficiency your Mini won't notice any. The chances of what is noticeable to others is it aftermarket LED conversion. Potential issues are many, such as lack of uniform dispersion, dimly lit light when its supposed to be off...
Old Nov 10, 2017 | 03:16 PM
-=gRaY rAvEn=-
Moderator
I just purchased second set for Toyota Highlander - an eBay Special....work phenomenal and were only 15 dollars !! What I found was that with the H7 and H4's they can be installed incorrectly with respect as to where the LED's are situated. If a H/L beam H4 the bulbs should be installed so LED are horizontal or in other words, so the LED boards are to the left and right. If not done this way, odd shaped light patterns result.
I would do the same with the H7's used in most MINI lights. Just keep rotating the bulb around 45* at a time until optimum results are achieved. The H7's have a notch so may not have to do this on a MINI.
https://www.ebay.com/itm/940W-141000...72.m2749.l2649
