Interior/Exterior Stealth Turn Signals
Old Oct 7, 2004 | 02:12 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
I just ordered a set of Sylvania Silverstar turn signal bulbs (7507ast). I was wondering if anyone has changed/replaced theirs? If so, Was it hard? and can you give me some pointers on what to do or not to do? Or can someone direct me to a previous thread? I like doing work myself but I hate finding out there was an easier way to do it later.
thanks
golden_child
Old Oct 7, 2004 | 02:29 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I replaced mine with Silverstar 1156 equivalents. The bulb wattage and size is correct, but I had to grind off one bayonet pin to make them fit. They look better than the 'fried egg' of the stock bulbs and flash normally in amber. The replacing of the bulbs themselves is easy, requiring no tools or disassembly. Open the bonnet, twist the bulb holder and remove it. push and twist the bulbs counterclockwise to remove, reverse the process to reassemble and you're done.
Old Oct 7, 2004 | 02:54 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
It's in your owners manual if you want pics...install is very simple
Old Oct 7, 2004 | 03:01 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
This holds true for the stock rear lights but doesn't for the MINI white tail lights that have bulbs that are soldered into the sockets. In that case you'd need to go back to the stock light assembly and use colored light bulbs for stop and turn signals.
Old Oct 8, 2004 | 12:51 PM
golden_child
Thanks for the info. I should be putting them in on Monday. I hope.
Old Oct 9, 2004 | 07:14 AM
Rally@StanceDesign
Minihune, i think he meant the front turn signals? That's what i was pointing to in the manual...sorry if i misunderstood Golden_child
UncDeo
Nov 4, 2019 04:08 AM
rob&JCW
Feb 21, 2018 02:41 PM
molala
Oct 2, 2015 01:53 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Suspension Products
Sep 2, 2015 10:32 AM
