Interior/Exterior shedding S.roof weight
Old Jun 19, 2016 | 09:51 AM
cguzz's Avatar
cguzz
So the front sunshade ripped yesterday. Not willing to pay $140 to replace it since it's of little use in shading the sun. I've ordered a pair of ZippyShades and I'm considering taking out both the broken front and the rear to shave off weight. They probably don't weigh much but just like the hot side muffler and noise maker, I like to remove and discard useless items.
Doesn't seem too difficult to replace but wondering if things would still operate if I simply remove and discard them?
Anyone tried this before?
thanks!!!
Old Jun 23, 2016 | 09:02 AM
Dimitris Sofianopoulos's Avatar
Hi, yes you can do it and everything works perfect. To remove them you have to unscrew the torx bolts that holds the sunroof glass, remove it carefuly, get the sunshade out then reinstall the glass.
Old Jun 23, 2016 | 09:25 AM
cguzz's Avatar
cguzz
Thanks Dimitris
Old Jun 28, 2016 | 09:53 AM
Hope I helped a bit . I got it out and trying to glue the net to the spring and I will reinstall it. I refuse to pay that amount of money for that cr@p! If you remove it, it has kind of hole where the plastic grip was when it was closed and I dont like that!
Old Jun 28, 2016 | 09:59 AM
cguzz's Avatar
cguzz
My front one started tearing away and the driver side then the spring or metal band broke. I tore away the shade and removed the spring and stuck a zippie shade in there. I was thinking I should have just had them tinted 5%. I'm leaving the frame there especially now that you tell me there's unfinished looking void when you remove it.
Sidewalker
Jul 8, 2016 10:44 AM
heavyJ
May 22, 2016 05:34 PM
1st JCW
Apr 16, 2016 09:33 AM
spikeyadrian
Apr 1, 2016 07:51 AM
go_mini_go
Mar 31, 2016 04:57 AM
