Interior/Exterior 05 euro plates
Old Aug 26, 2004 | 10:29 AM
trickedmotoring's Avatar
trickedmotoring
euro plate install (help)
hey everyone, i just got my 05 mcs. and i want to put a euro plate on it. i have the plate and the bracket. i just unsure of how to mount it. it seems like i need to remove the front bumper, to get the bolts in. if anyone has done this i would really like your help and/or where i should go to get it done
thanks
Old Oct 12, 2004 | 11:16 AM
mini_this's Avatar
mini_this
05 euro plates
i used 3m double sided tape. it works awesome just prep the area with some cleaner to get all the grime and wax off of it. i also realized that the black plastic frame that i had for the plate did not adhear well. i just bent the plate a bit and put double sided 3m tape. it is sturdy as hell and its been on for 4 months now.
Old Oct 12, 2004 | 01:31 PM
ImaVunDerBrah's Avatar
ImaVunDerBrah
Attached a euro plate to my Cooper using double sided tape as well. Granted, the Cooper has a 'spot' for the Euro plate, but I assume it'd work on the MCS just as well. I didn't totally clean the spot and used basic 3M mounting tape (like kind for walls and such) the first time and the edges of the plate kept popping up. Second time around I got double sided tape from an auto parts store and cleaned the area really well....that sucker never moved!
Old Oct 13, 2004 | 06:48 AM
bolar's Avatar
bolar
The MCS's bumper is curved and doesn't really have a place for a plate. Unless your plate is curved I don't think double sided tape would be a good idea.
I used the holes that were there from my North American plate. The screws are the self tapping type and hold it tight.
Old Oct 15, 2004 | 09:24 AM
jebernauer's Avatar
jebernauer
I just bought a custom plate from Germany and they sent it with a nice plastic bracket that you slip the plate into after screwing it on. No visible screws... not gonna come off anytime soon!
Old Oct 15, 2004 | 09:34 AM
kramseib's Avatar
kramseib
The easiest way is to move to Europe like I did. But then again, the military moved me so it was no cost to me.
Old Oct 15, 2004 | 11:19 AM
DSA's Avatar
DSA
I had the same delimma so Iwent to walmart bought dry wal screws the kind with the teeth on the nut , drilled the holes screwed in the screws you know the kind that expand and have the little pointed palstic tip screwed em in and a year later they are good as new. I did check it for about 4 months every time I stopped being dry wall screws but to my delight the worked perfect.
Cost about $3.00
and a lota nerve to drill my coop.
photos if you want just pm me.
Old May 14, 2005 | 05:17 PM
dmeyer's Avatar
dmeyer
Anyone know if Euro plates are legal in Ohio? Those that have them, do you have standard plates on the rear and Euros on the front (assuming your state only requires one plate)?!?
Old May 14, 2005 | 05:31 PM
mbabischkin's Avatar
mbabischkin
Quite simply:
If your state doesn't require a front plate than the Euro plate is probably legal...
If your state does require a front plate, then the Euro plate is probably ILLEGAL. Install at your own risk...
That being said many people have Euro plates on their cars in states where they are required and have never been hassled...
Old May 15, 2005 | 05:24 AM
azuul's Avatar
azuul
Originally Posted by mbabischkin
Quite simply:
We have a guy in the South TX MINI Club who got the plates with his legal TX plate number. He put the euro plates in the front and the back (TX does have a front plate - grrrr). He's been stopped a few times, but when the police run a plate check the numbers agree, so they have let him go every time, with no ticket.
Old May 15, 2005 | 05:37 AM
mbabischkin
I think he should consider himself lucky...
Old May 15, 2005 | 06:08 AM
red rage's Avatar
red rage
which plates are the best, coolest, offciial ?
B, D, E, F, BG ...????
Old May 15, 2005 | 06:29 AM
matthewz's Avatar
matthewz
Care to expand or expound those abbreviations up there?
Old May 15, 2005 | 05:12 PM
mbabischkin
Ummm... huh?
What do those abreviations mean?
You don't know what you like?
Old May 15, 2005 | 06:34 PM
CustomAV's Avatar
CustomAV
I have an MCS with a euro plate bracket. I actually used nylon zip ties and looped it through some spaces in the bumper grill space. It holds just fine. You can look at my pics section of my website to see it.
It is currently off of the car since I am have the new aero bumper painted. I will happily take pics of the process if you like?
It works well since the euro mounting has a lot of holes and places for the zip ties to work around and I made sure not to pull them tight allowing the plate to stay flat on the curved surface.
Chris
Old May 15, 2005 | 08:22 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
British (should really be GB)
Deutsch
Espana
French
Belgium? just a guess
Old May 15, 2005 | 08:38 PM
Itsdchz's Avatar
Itsdchz
gotta love going Euro!
Old May 16, 2005 | 07:04 AM
HMC's Avatar
HMC
ZIp Ties
Zip ties are a God-send at times! But I would re-check them monthly, because I had a bad experience with them on my bike. After a while, heat and age tends to make them brittle.
-Pete
Old May 16, 2005 | 09:58 AM
azuul's Avatar
azuul
True, but no more. He was stopped on the way to our second annual Big Bash at the Big Bush and got a ticket for non complying plates (even though he had the real ones in the car with him).
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
