Interior/Exterior Real Carbon Fiber
Old Jan 27, 2016 | 09:11 AM
minihooligan773's Avatar
minihooligan773
Real Carbon Fiber
Started doing real carbon overlay on some of the interior parts. Still not done but going ok so far. Process is pretty simple but need at least 4-5 days to complete. Carbon fiber sheet and glue got from amazon for $22 a kit. Ill do a step by step write up soon too.
Attached Thumbnails Real Carbon Fiber-img_0079.jpg   Real Carbon Fiber-img_0080.jpg   Real Carbon Fiber-img_0081.jpg   Real Carbon Fiber-img_0088.jpg   Real Carbon Fiber-img_0089.jpg
Real Carbon Fiber-img_0090.jpg   Real Carbon Fiber-img_0110.jpg   Real Carbon Fiber-img_0111.jpg   Real Carbon Fiber-img_0112.jpg
Old Feb 1, 2016 | 09:23 AM
minihooligan773
Cup holder, speedo cover, shifter cover all done.
Got speedo apart doing it now.
Attached Thumbnails Real Carbon Fiber-img_0149.jpg   Real Carbon Fiber-img_0150.jpg   Real Carbon Fiber-img_0151.jpg   Real Carbon Fiber-img_0136.jpg
Old Feb 2, 2016 | 08:04 AM
minihooligan773
Parts installed
Old Feb 2, 2016 | 01:26 PM
YO MUDA's Avatar
YO MUDA
Looking good brother.
Old Feb 2, 2016 | 06:21 PM
MiniLife's Avatar
MiniLife
Originally Posted by minihooligan773
Parts installed
Not bad at all! Id definitely give it a shot if you make a write up. Nice job
Old Feb 3, 2016 | 11:00 AM
minihooligan773
Parts needed:
Scissors
Food scale
Utility Knife
Sand Paper: 250, 400 or 600 and 1000 or 2000 Wet
Non Wax Cups
Small brushes
Mixing sticks
Clear coat
Heat Gun
3M 77 or 90 spray glue (home depot has it)
Carbon fiber sheet and Epoxy should be UV stable, and chip resistant (
Amazon.com: Real Carbon Fiber Epoxy Resin Kit - 2x2 Twill 36 Amazon.com: Real Carbon Fiber Epoxy Resin Kit - 2x2 Twill 36" x 6": Industrial & Scientific
Lots of spare time
Step 1:
Remove all the parts you want to wrap. Use 250 sandpaper scratch the whole area so the glue will grab good. You are basically trying to get the shinning clear coat off so glue sticks down. Wash off with water and small amount of soap or use brake cleaner.
Step 2:
Pre cut the amount of Carbon Fiber to cover the area you are doing with a 1/2" of excess to over hang. Good note to use tape on back so carbon wont start to unravel.
Step 3:
Spray on the 3M 77 or 90 glue and let sit for minute or so i can tell its set once it barley sticks to your finger (once set its easier to lay carbon fiber down with out it moving on you). DO NOT CUT OVER HANG YET. Should look something like this.
Step 4:
Mix epoxy to the specifics, use scale to weight, make sure its correctly mixed so will set correctly. MIX SLOWLY SO NOT TOO MANY AIR BUBBLES FORM IN EPOXY.
Step 5:
Apply even coat to the whole area. Use Heat gun on Med to get all air bubbles out. Let the 1st coast dry for at least 24hrs. Do not cut off overlay yet wait till 24hrs drying period is done.
Step 6:
Cut off all the overlay you have this will help after waiting 24hrs so it wont untangle itself. Should look something like this.
Step 7-10:
Do at least 5-6 coats of Epoxy waiting between 6-7hrs between coats. Use a heat gun after you apply each coat on med heat you will see small air bubbles popping out will help to keep everything smooth between coats. After last coat let dry for 24hrs.
Step 11:
After 5-6th coats and dried for 24hrs start with 250 sand paper sand entire surface. Then move down to 400 and down to 1000 wet. Should look like this.
Step 12:
Clean surface with brake cleaner or isopropyl alcohol no more then 75% alcohol.
Step 13:
Clear coat should be applied to specs on spray can should do at least 3 coats, I did 6 to save it from ever turning yellow from sun rays. After 6 coats should look like this.
Step 14:
If clear coat got any bubbles or anything resend with 1000 wet and clear coat again.
Step 15:
Reinstall all part, step back and enjoy.
If any questions on steps please ask can help out with it no problem.
RussMorris
May 31, 2016 07:11 AM
ClubmanJCW
Mar 1, 2016 06:00 PM
zipitydooda
Feb 10, 2016 08:29 PM
U.S.A. Ranger
Jan 25, 2016 01:36 PM
cdavidell
Jan 20, 2016 01:46 PM
