Interior/Exterior Interial Side pole
Old Aug 18, 2004 | 01:25 PM
ultramini's Avatar
ultramini
how to remove A-Pillar cover for 2003 Mini Cooper
Hi All,
Do you have instruction of how to remove the front A-Pillar and sunroof switch? I try to install the Bluetooth kit. I want to route the mic cable to the sonroof switch area.
I was reading the Bluetooth kit instruction from motoringfile.com. It mentions that the A-Pillar cover is a one time use component and must be replaced with a new part. Since the instruction is for MINI after Feb 2004 Does it apply to the 2003 MINI?
Also, anybody has solution to use the Sony HCE-16 mute cable with HK unit? Thank you very much for your help.
UltraMINI
W0TM8
Dec 19, 2019 07:50 AM
Ollie625
Nov 15, 2015 06:57 AM
MCSDTP
Sep 8, 2015 12:03 PM
cm.d
Aug 19, 2015 08:51 AM
