Interior/Exterior P3 Cars integrated gauge install
Old Nov 2, 2015 | 08:35 AM
georgebriggs's Avatar
georgebriggs
Hey all, the guys at P3cars.com sent me there integrated digital interface to try out after some radiator issues went ugly. As you all are likely aware the lack of info on the dash really sucking on the Mini, there is much to be desired, which has caused a fair amount of issues for myself, especially while tracking.
I was quite adamant about trying the P3 gauge given it's "stock" look and didn't want a huge cluster of gauges messing with the interiors lines. I've attached a video of my review (as well as an intro to the build I'm starting on it) from my YouTube channel I run but here are a couple pointers I didn't mention that may be notable in hindsight.
Construction: It looks like it was 3D printed which I was sceptical at first however once installed it looks really sharp.
Features: Apart from the array of gauges available at the touch of a button, there are analog wires if you want to add further readings to the gauge.
Upside: Sleek "OEM" like design, I won't say it's perfect but I really like it. Tons of info, likely more than I need. 0 to 60 isn't a selling point for me but fun none the less. Really easy to install, probably took 15 min to do max. I'm a lot more conscious of how I drive. Not exclusive to P3, but the LED reading in the line of sight with the tachometer keeps temps visible at all times.
Downside: It's not the cheapest at $399, however if you're planning on throwing on a few gauges, you're already past the $ amount. You only get one reading at a time, for me that's plenty however I could see a benefit of having boost and coolant temp available to view at the same time while tracking.
Hopefully you'll find this helpful, I'll be doing various other installs and reviews on my Mini as I go through the build.
Old May 9, 2016 | 04:31 PM
geowyatt's Avatar
geowyatt
P3
I also installed a P#. It was pretty simple. I have a 2009 CooperS turbo and the temp guage runs at 220 degrees while driving. I called P# and got " maybe small engines run hot" Anyone have a good answer for me?
Old May 9, 2016 | 04:59 PM
sdiver's Avatar
sdiver
Installed my P3 Cars VIDI about 18-months ago...and that seems normal. My 2013 Clubman S runs about 215-230º F, a bit cooler in Sport mode.
Old May 9, 2016 | 05:20 PM
geowyatt's Avatar
geowyatt
Cool! Thanks , I just wanted to make sure the dang squirrel cage wasn't going to blow up
Old Jul 26, 2016 | 11:50 AM
bugeye1031's Avatar
bugeye1031
Moderator
I really like this approach, but $399 is just too much....running Torque pro on an old phone right now....replaced my ScanGauge II.....
Neither is pretty, but the Torque/phone approach is functional and cheap....too many other mods to spend on right now!
Old May 24, 2018 | 05:08 PM
BlueCooperS's Avatar
BlueCooperS
I just installed on on my Roadster yesterday. It gives me some much needed gauges, but I do have a question. Where would the green "dimmer" wire hook up to?
Old Jun 3, 2018 | 10:36 PM
DGI's Avatar
DGI
Ive got the JCW gauges (coolant temp and G force) and want more info as well. Debating stripping out the JCW stuff for a P3 or adding a Scan Gauge somewhere... not sure how accurate JCW gauge is
Old Sep 4, 2018 | 05:00 AM
carpecervisi's Avatar
carpecervisi
Malaysk ROM
disregard....my bad
Old Jan 7, 2022 | 06:39 PM
b.coate's Avatar
b.coate
P3 Gauge install on an R60
I am trying to install the gauge but unfortunately they don't have any documentation and I can't seem to find anything on the internet. I think I have the gauge installed in the right spot but the wire doesn't look right. Any ideas?
GrayGhost
Jun 7, 2016 06:33 PM
SpyderDNA
Mar 29, 2011 07:00 AM
orangecrush
Feb 2, 2010 10:44 PM
Mach V Dan
Jul 25, 2007 10:07 PM
TonyB
Electrical
Sep 18, 2006 01:35 PM
