Interior/Exterior Exhaust tip mystery
Old Aug 6, 2004 | 10:44 AM
MSFITOY's Avatar
MSFITOY
Exhaust tip mystery
I've had my Borla Race exhaust for over a year now and just within the recent days, I've discovered that the tip rises after a half hour drive. It actually melted the trim. I've disassembled and reassemble the clamps at the rear but no matter how tight I torque them on, they keep rising and I keep pushing it down
I can't figure out what's with this Any suggestions?
Old Aug 6, 2004 | 10:54 AM
early_apex
I've seen my JCW and a friend's Milltek stick out a little when the exhaust is hot. I've only seen them go straight out, never up, but they defanitly expand when they are hot. Maybe yours is pivoting on a hanger causing it to touch the body.
Old Aug 6, 2004 | 11:11 AM
AMPR's Avatar
AMPR
You might want to have it welded in place. I had mine welded in place and haven't had any problems whatsoever.
Old Aug 6, 2004 | 01:03 PM
JCampos's Avatar
JCampos
This exact same thing happens with my Magnaflow and I havent bothered trying to fix it or even take a look at it. I did however rip that little piece of melted plastic off :P
Old Aug 6, 2004 | 01:20 PM
Moorlockx's Avatar
Moorlockx
The tip movement is definitely heat related. The metal expands as the normal operating temp is reached. My Magnaflow will "grow" about 3/4" in length. They always move straight out as mentioned by early_apex. I've never had a curving problem.
Old Aug 6, 2004 | 01:21 PM
JCampos's Avatar
JCampos
mine dont curve, they just seem to lift up a bit.
Old Aug 7, 2004 | 08:05 PM
MSFITOY's Avatar
MSFITOY
After the fifth time I jumped out and cursed the pipes...I stuck a wrench into the tail pipe and looked underneath as I pushed down. AH HA...it was the clamps ahead of the mufflers that were loose. No one got that right
embiggenedmini
Oct 15, 2015 12:36 PM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
