Interior/Exterior Seat Belt Tensioner's Black & Blue Connectors
Old Dec 10, 2014 | 04:33 PM
TonyB's Avatar
TonyB
I removed the OEM front seats and installed one aftermarket seat thus far, the driver side of course, and decided to go for a spin, and noticed the SRS light is on.
I put the appropriate resistor into each yellow airbag connector beforehand, so I imagine that is not the issue. Since the passenger seat is not installed now (and the belt receptacle), might that be the problem, that the blue and black connectors for the tensioner are not connected? I'm guessing so...
If that is indeed the case, should one put a resistor in those too, when not being used. Not sure when I'll install the passenger seat....
Thanks much.
Old Dec 10, 2014 | 11:29 PM
chris.j.lamb's Avatar
chris.j.lamb
Yes and you will need a code scanner/resetter to turn off the SRS warning light as well.
Old Dec 10, 2014 | 11:46 PM
TonyB's Avatar
TonyB
Chris, thank you for making the time to respond. I have two more of the same resistors. Do you know if those work here too (same resistance), in these connectors?
Seems that I might need to purchase something like this:
http://www.obdtoolstore.com/shop/pro...3dbbd4031beb7f
A $60 mistake because I wanted to go for a spin so soon... Drat.
sevin
May 2, 2026 06:11 AM
tr3y003
Oct 22, 2015 10:48 AM
Aug 7, 2015 09:51 AM
