Interior/Exterior Colored LED Dome Lights
Old 05-10-2007, 01:16 AM
ellistotle's Avatar
ellistotle
ellistotle is offline
kyriian, you might want to try taping some foil to the housing behind the light bulb. i did that to the footwells and the difference in the light output is pretty great like someone already mentioned in this thread. it looks GREAT in red and i LOVE it
i used the 9 led festoon bulb for the dome, which was much brighter then the previous one i ordered. used the foil, and was a bit brighter. ill try to post pictures up this weekend!
  #252
Old 05-15-2007, 09:14 AM
Mach V Dan's Avatar
Mach V Dan
Mach V Dan is offline
We put together LED lamp kits for both generations of MINI. I put Super White ones in our shop car:
You can find the kits HERE.
--Dan
Mach V
FastMINI.net
  #253
Old 05-15-2007, 09:26 AM
IrishCooper's Avatar
IrishCooper
IrishCooper is offline
I went to the site, where are the 10 blubs you listed? I counted on my 06 MCS
2 next the dome, 2 in the front by the mirror, 2 in the footwells, and 2 in the puddle lights on the doors. What am i missing?
EDIT: Nevermind, i noticed you said there was one for the glovebox and the boot light, so if i dont need some of these cause i already have them can i get a partial kit?
  #254
Old 05-15-2007, 11:32 AM
Mach V Dan's Avatar
Mach V Dan
Sorry, we just sell the complete kit to keep things simple. If you want, donate the spare bulbs to another MINI owner. Good karma...
--Dan
Mach V
FastMINI.net
  #255
Old 05-16-2007, 10:12 AM
IrishCooper
Do you have pictures of the bulbs that you use?
  #256
Old 05-18-2007, 09:03 AM
Mach V Dan's Avatar
Mach V Dan
Here's a picture of one of the multi-directional ones. (It's not in a MINI.)
--Dan
Mach V
FastMINI.net
  #257
Old 05-22-2007, 06:18 PM
Mach V Dan's Avatar
Mach V Dan
Here's a couple of shots with the blue LEDs in the car.
--Dan
Mach V
FastMINI.net
  #258
Old 05-22-2007, 06:27 PM
MLPearson79's Avatar
MLPearson79
MLPearson79 is offline
Holy crap. That is blue to a whole new level!
And I kinda like it.
  #259
Old 05-22-2007, 06:29 PM
lilruffcat's Avatar
lilruffcat
lilruffcat is offline
ok, i knew i would bite on this.. dammit.. another something i want for my lil union jackie.. so where is this bulb kit.. and how hard is it to do.. your talking to a mod novice..w ith no electric experience..
cat
  #260
Old 05-22-2007, 07:17 PM
Mach V Dan's Avatar
Mach V Dan
cat
Bulb kit is HERE.
It's pretty easy, but a little tedious. The map light bulbs, in particular, are a real PITA to get out. I ended up completely disassembling my overhead switch/lamp cluster, partly because I couldn't get the bulbs out, and partly because I just wanted to see what was in there.
Next time I'll just use a little pick and get the bulbs out that way...
A small flat screwdriver (or your fingernails) will pop the cover off all the bulb housings in the doors, footwells, glove box, and the boot.
I also wrote up a little FAQ about LEDs, which might help.
--Dan
Mach V
FastMINI.net
  #261
Old 05-22-2007, 07:45 PM
rkw's Avatar
rkw
rkw is offline
Did you mean for the R56? It's pretty easy for the R50/R53 (hardtop) and R52 (cabrio). For the hardtop, see post #161. For the cabrio, see post #108. Actually for the cabrio it's much easier than described there -- simply insert a credit card into the rear edge (away from the mirror) and push in to release the light module. I'll try to post a picture tomorrow.
  #262
Old 05-22-2007, 07:55 PM
Mach V Dan's Avatar
Mach V Dan
Originally Posted by rkw
Did you mean for the R56? It's pretty easy for the R50/R53 (hardtop) and R52 (cabrio)...
Oh yeah, sorry, forgot where I was. Yes: R56 map lights, pain. R50/52/53, easy.
--Dan
Mach V
FastMINI.net
  #263
Old 05-22-2007, 08:37 PM
Duck360198's Avatar
Duck360198
Duck360198 is offline
Hey Mach V Dan, you don't have pics of the bulbs in an R53 do you?
  #264
Old 05-23-2007, 06:19 AM
Mach V Dan's Avatar
Mach V Dan
Sorry, not yet.
--Dan
Mach V
FastMINI.net
  #265
Old 05-23-2007, 08:32 AM
Foxtrot_Xray's Avatar
Foxtrot_Xray
Foxtrot_Xray is offline
Okay, I'll throw a question out there.. what about the white plate lights on the outside of the boot?
  #266
Old 05-23-2007, 08:43 AM
Loony2N's Avatar
Loony2N
Loony2N is offline
--Dan
Mach V
FastMINI.net
"For 2007+ coupe models, we don't yet have a panel-style dome light replacement" Do you have this yet?
  #267
Old 05-23-2007, 10:42 AM
Mach V Dan's Avatar
Mach V Dan
No. When I do, the web site will change, and I'll announce it somewhere on these forums.
--Dan
Mach V
FastMINI.net
  #268
Old 05-23-2007, 10:44 AM
Mach V Dan's Avatar
Mach V Dan
I'll have those available soon, but they may require additional resistors to keep the car from thinking the lights are out. I'll post up when I have a kit available.
Another LED exterior light: See the little bumper marker lamps below. (Stock bulb on passenger side, LED bulb on driver side.) The LED matches the HID color pretty nicely. But, as I mentioned above, the resistance is different than the stock bulb so I'm working on a resistor for it.
--Dan
Mach V
FastMINI.net
  #269
Old 05-23-2007, 06:27 PM
Duck360198's Avatar
Duck360198
Maybe I missed it, but I was reading a post on soldering. Do these require soldering, or is it a simple swap out?
  #270
Old 05-24-2007, 07:31 AM
ImagoX's Avatar
ImagoX
ImagoX is offline
AWESOME NEW PRODUCT!
Oznium just put out a 4 chip, 16 or 25 LED dome light wafer! These things look incredible! Every LED unit comes with an adapter set which allows you to use them with 194 plugs, festoon-type sockets - basically any dome light area. These could easily be used as 194 replacements as well with a little imagination. Given the LEDs he chose to use, these babies must be VERY bright, and they're available in many different colors. Makes me wish that I had a real dome light...
  #271
Old 05-24-2007, 07:52 AM
Mach V Dan's Avatar
Mach V Dan
None of these bulbs require any soldering. However, if you are trying to replace exterior lights, the LEDs will look like an open circuit to the car (because of their different resistance characteristics compared to a normal bulb), and you would want to install a load resistor across the circuit. Although these normally come with tap connectors, I don't really like those, and I'd recommend proper soldering if possible.
--Dan
Mach V
FastMINI.net
  #272
Old 05-24-2007, 07:54 AM
Mach V Dan's Avatar
Mach V Dan
Those are cool, but I don't think there's any way they'll fit in any of the MINI dome or map light fixtures.
--Dan
Mach V
FastMINI.net
  #273
Old 05-24-2007, 08:10 AM
ImagoX's Avatar
ImagoX
ImagoX is offline
I'm not sure either - my cabrio only has space for a single 194 5 LED bulb, but I know that the hard tops have a more traditional plastic dome light shield. Just thought I'd mention it since the product could very easily be used as footwell accent lighting (just use the 194 adapter and the OEM lamp housing, then stick the array anywhere you like) or even in the boot (use a festoon or 194 adapter depending on your car, then adhere the array to the underside of the privacy tray... Uses are only limited by imagination with something like this.
  #274
Old 05-24-2007, 08:43 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
i think this LED array is probably the largest one you can fit in our dome lights: http://www.mossmini.com/Shop/ViewPro...34&SortOrder=1
  #275
Old 05-24-2007, 09:36 AM
robr3004's Avatar
robr3004
robr3004 is offline
Sweet....Oznium has some awesome stuff.....just put in an order for two 25 LED squares for my foot wells....LED bulb replacements I have now just aren't bright enough.
Quick Reply: Interior/Exterior Colored LED Dome Lights
