Removing radio dial knob
Subscribe
May 28, 2014 | 04:37 PM
Hello, I need to replace the radio dial **** but I don't know how to remove them. Does anyone know how to do this? Thanks!
Removing radio dial knob-2011-mini-cooper-clubman-2-door-coupe-audio-system_100347799_l.jpg
Reply 0
May 30, 2014 | 01:46 PM
They are right here:
Button for Menu Part # 65123456864
http://www.ecstuning.com/Search/SiteSearch/65123456864/
Button for Volume Part #65123456863
http://www.ecstuning.com/Search/SiteSearch/65123456863/
I believe that snap in like the older silver ones on the Gen 2 MINIs. Just pull off and snap a new one in. The rod that you insert them on has a notch for the direction of the hole.
Reply 0
Aug 9, 2014 | 11:06 PM
I tried pulling it but no luck.... Any suggestion? Thanks!
Reply 0
Aug 11, 2014 | 07:05 AM
Should come right off, snap on. They have a little tab built into the hole slot. Try both hand pinching from the top and sides.
Reply 0
Oct 20, 2022 | 10:33 AM
silly question, but has anyone changed out the color OR design of the **** that controls the functions of stereo, and NOT the volume? I constantly go to reach for the mode control **** and NOT the volume **** when I want to turn down in a hurry. If I had a flat nosed ****, compared to the cone shaped, perhaps the feel/look will deflect me to the proper volume ****...
Reply 0
Oct 20, 2022 | 11:12 AM
Yep they look the same. New one has the on/off icon on it. See above. I have not seen one, i guess you could
Older version, no on/off Icon.
Reply 0
Oct 20, 2022 | 01:52 PM
actually, the ***** I was referring to are part numbers 65123448285 & 65123448286 and the #3 being the one I was referring to. They have a different length neck. I am thinking I can grab one from a pick-n-pull location and grind it down flat, so that its physically different than the volume ****. then once I'm comfy with a modified used ****, I'll just buy a fresh new one and modify that too.
Reply 0
Oct 21, 2022 | 08:17 AM
Ok thats the older 2007-2010 set up
https://www.ecstuning.com/Search/Sit...h/65123448285/
https://www.ecstuning.com/b-genuine-...p/65123448286/
2011+ on the left / 2007-2010 on the right
Yea i know, i had my 2007 i would quick grab to the center, its a habit. No aftermarket larger ones i can think of unless you try one of the black ones from the 2011+ if that one will work
Reply 0
Subscribe
