Interior/Exterior Bonnet Stripe Installation ?
Old Aug 18, 2013 | 09:48 AM
breyfogle's Avatar
breyfogle
Installing vinyl striping seems easy enough to DIY but is there anything not obvious that would make installing stripes *WELL* difficult ?
Is there any pro or con WRT using factory MINI stripes versus on-line vendors ?
Old Aug 18, 2013 | 10:01 AM
CR&PW&JB's Avatar
CR&PW&JB
I've found no substantial quality difference in OEM vinyl vs the vinyl most of the aftermarket vendors use.
As far as install, decide if you want to do a dry install or wet install. Wet install is more forgiving so for the first time installer, I'd recommend that method. Or, if you're installing sport stripes I recommend wet method because they're a little more difficult.
caiken
Aug 27, 2015 06:55 AM
minicoclub
Aug 25, 2015 09:07 AM
bctf1
Aug 6, 2015 12:55 PM
