Interior/Exterior How can I disassemble center console glass
I prefer brevity. Extrememly complex process best left alone. Several have asked that question, had it explained to them and they turned and walked away. I'm one of the several but I didn't ask, just observed.
I think there may be some info in the Gen 2 "infotainment" area since the stereo is integrated to the speedo face.
I did take mine apart and it was a PITA. There are screws beneath caps on top of the dash in the vents that are behind the emergency flasher button. You also have to remove a good number of other surrounding dash components to release the center stack.
Good luck.
Watch the video and skip the steps you don't need. Once you have the trim panel in front of the speedometer off, you don't have to actually remove the entire speedometer. You can press on the clips to release the clear front lens.
Also look at these instructions: http://www.fes-auto.com/upload/doc/5...tion_Guide.pdf
xraycat
Aug 12, 2015 02:36 PM
