Interior/Exterior questions for anyone who has installed their own oem rally
1. how do i remove the passenger side kickpanel to gain access to the control module? 2. is it possible to wire the lights to come on with the parking lights rather than the high beams? 3. how can i seal up the small hole i made in the grommet surrounding the wire harness ? thanks in advance for your help !
Take the weather stripping off. Get a good grip of the panel along the edges of the kickpanel and pull away as hard as you can. After pulling it out, you should be able to push the kickpanel out of the way to gain access to the wires. If desire, it can be completely removed after unscrewing the bolt holding the seat belt harness; however, it's not necessary.
Yes, by connecting the remote lead to the parking light wires
I use electrical tape to wrap the wires after puncturing the existing grommet under the driver side vent.
Good luck! :smile:
Good luck! :smile:
davecsumini, is the remote lead the yellow wire going to the control module? if yes, where is the parking light wire ? or do i need to feed the yellow through the grommet to the parking lights in the engine compartment? thanks for your help !!!
Is the remote lead the yellow wire going to the control module?
I don't remember the color of the wire, but it's the wire going to the on/off switch.
Where is the parking light wire? or do i need to feed the yellow through the grommet to the parking lights in the engine compartment?
Instead of running the wires back to the engine compartment to the parking light, find any wire that powers dash illumination when the parking light is on. If you mount your switch near the steering wheel, the closest wire should be the grey/pink wire of the harness going to the Tach above the steering wheel.
If you tap into the parking light or illumination wire as suggested, the aux light is operable as long as the parking light is on. :smile:
blackie
Oct 2, 2015 07:41 PM
squawSkiBum
Oct 2, 2015 09:21 AM
JHolland
Aug 13, 2015 10:47 PM
