Interior/Exterior Voodoo Vs. Whalen shift knobs
Old Mar 7, 2004 | 04:18 PM
elbee's Avatar
elbee
From what I've read the Whalen is the best. Does anyone have the Voodoo know? http://www.teamvoodoo.com/Voodoo/*****.html I met a guy last night with an S2000 and he said he loves the Voodoo, he said it was around $75.
Old Mar 7, 2004 | 06:29 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Although Voodoo ***** look very similar to Whalen's and quite a bit cheaper, Whalen caters specifically to MINI and BMW cars with custom designs and logos. I don't know how well the Voodoo will fit on the MINI. :smile:
Old Mar 7, 2004 | 06:37 PM
no_affiliation's Avatar
no_affiliation
I checked the applications and the mini isn't listed.
Old Mar 7, 2004 | 06:42 PM
05JCWS's Avatar
05JCWS
You picked the wrong board for an unbiased opinion. I think there is a large majority here who love the Whalen ****. I love mine and haven't found a **** like it. If Doug builds a handbrake lever I will be in heaven. The feel of the Whalen and specifically the weight is great. It is much heavier than the stock and gives it an added feel.
Old Mar 7, 2004 | 07:09 PM
kgmini's Avatar
kgmini
I had a titantium Voodoo **** on my S2000. It was very nice and much better than the stock AL ****. Titantium is very dense and makes for a very heavy ****. Voodoo specialized in Miata ***** and we (S2K owners) persuaded them to create a **** for the S2K. Much like the Whalen is to MINI's the Voodoo is to the S2K. I wouldn't knock either ***** since they are both of excellent quality. My MCS is due next month and I planned on buying a Whalen, but it would be nice to see somone else produce a quality **** for the MINI.
Old Mar 7, 2004 | 10:00 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Although titanium is about twice as dense as aluminum, stainless steel is about 3 times a dense as aluminum. My Whalen **** weighed in at just over 500 g.
_________________
SHOW ME THE NUMBERS! 1/4 Mile Database
Old Dec 12, 2005 | 06:49 AM
mcswrks's Avatar
mcswrks
I bet the guys at Lotus wouldnt like that!
Old Dec 12, 2005 | 06:50 AM
The Short Bus's Avatar
The Short Bus
I didn't feel like starting a new thread, but i decided to ask my wonderful dad for help on figuring out a way to put my beloved Voodoo **** in my MINI. And , well... he found a way... that i'm still trying to clean up
We just popped the old **** off, and drilled three set screws into the voodoo **** right above the stainless collar, and i just screwed them into the plastic that holds the stock ****. I need to move the shift boot up so it doesn't look so goofy, but you get the idea. The shifts have cleaned up SO well, and i love how tiny my **** is. Since i haven't driven a mini with a Whalen, i can't say how much different that is... but i love my voodoo
Also, excuse the messy mini
If i find out how to take the plastic part off, we may just thread the Voodoo onto the shaft.
The Short Bus
How did we both search for this forum and post at about the same time?
Old Dec 12, 2005 | 06:54 AM
mcswrks's Avatar
mcswrks
Haha, Im not sure...Look into your MINI's crystal ball....It will tell you the answer...
Old Dec 12, 2005 | 07:33 AM
fishbulb's Avatar
fishbulb
SB....
you know that you are going to have to give us a detailed account of how you made this work, right?
looks good!!!
-jac
Old Dec 12, 2005 | 07:43 AM
The Short Bus
Originally Posted by fishbulb
SB....
looks good!!!
-jac
You were the first person i thought of when my dad offered to help me find a way to get it on there . Once i get the shift boot moved up i'll take more pictures... and if anyone knows how to take that plastic off it'd help too.
Like i said before, pull the stock **** off (or get your dad to if you're as weak as i am ) drill three set screws right above the stainless collar, put the voodoo **** on the plastic pushing it down as far as it will go. It doesn't have any play, but you just screw the set screws in as far as you can. Since the boot is zip tied on, i need to get that off and move it up. I'd LIKE to shorted the throw by taking off that plastic and screwing the voodoo on the shaft... but that'll have to wait.
Sucks i kept the **** in immaculate condition, and the person at the parts counter when my dad was picking up the screws dropped the **** and put a chip in it. Dangit! But i'm glad i have my pretty sparkly little **** back.
Old Dec 12, 2005 | 08:16 AM
VoiD's Avatar
VoiD
hmm interesting. great job!
what you need is a short shifter..
Old Dec 12, 2005 | 08:19 AM
The Short Bus
Thanks, and don't think i haven't been debating a SS kit
Old Dec 12, 2005 | 09:15 AM
Doug W's Avatar
Doug W
I'm just curious as to why the Voodoo **** doesn't slide down farther on the lever.
Is the hole in the **** not deep enough, or is it just too tight on the lever?
Old Dec 12, 2005 | 09:19 AM
The Short Bus
Fits perfect on the plastic... until it gets tighter for the threads near the top of the ****.
Old Dec 12, 2005 | 09:25 AM
Doug W's Avatar
Doug W
Let me know if you'd like it bored out, so it'll sit down lower.
whamac@msn.com
Old Dec 12, 2005 | 09:39 AM
ekibobrut1's Avatar
ekibobrut1
"heavy" shift *****
In the old days with my TR-3, it was determined that heavy shift ***** were causing some premature wear in the gearbox. Any one have an opinion if this might be a problem with our MINIS ?
Old Dec 12, 2005 | 04:01 PM
Crashton's Avatar
Crashton
I've got a Voodoo on my Miata. Very nice shift ****. If he sold one that would fit the MINI without redoing the mounting I'd buy it. The Whalen looks so good though. I may have to come up with a design for one.
http://www.teamvoodoo.com/Voodoo/TeamVoodoo.html
Chuck
Old Dec 13, 2005 | 07:57 AM
fishbulb's Avatar
fishbulb
i posted a while back a quote from VooDoo bob about the added expense of making the ***** for the MINIs & BMWs with the attachment set up that comes from the factory. Bottom line was that it costs too much....
However, if there was a common thread pitch for a lot of the after-market SSKs, I would not doubt that he would cut one...
Not to knock the Whalens (never tried one)....it's just that my Voodoo is the only thing i kept form my miata after 8 years of ownership!
-jac
Old Dec 13, 2005 | 08:14 AM
The Short Bus
I fixed the boot last night, just moving it up and tucking it under the ****. Looks better, but it's still too long. It's still really smooth shifting, but i want to get the plastic off and lower it.
And what does bored mean? lol.
Old Dec 13, 2005 | 08:40 AM
Doug W's Avatar
Doug W
I can make the hole bigger, so that the **** will slide down into its normal seated position.
Should take me about five minutes.
Old Dec 13, 2005 | 08:51 AM
LombardStreet's Avatar
LombardStreet
Moderator
Not a problem, as far as I know. In the old Brit sports cars, the shift linkage was attached directly to the gearbox. Pressing down on the **** could actually cause some wear inside the box. (I remember my wife's Austin Healey mechanic showing us some wear on one of the little doohickey's in a Healey box and telling us that's what happens when you rest your hand on top of the **** at stoplights!)
But under the MINI's shift ****, there's just a bunch of cables that go around to the gearbox which is w-a-y over there somewhere. Shouldn't be a problem as far as I can see. (I'm sure someone will correct me if I'm wrong. )
All the same, having said that, I still try to never rest my hand on top of the ****.
Old Dec 13, 2005 | 08:57 AM
gelstudios's Avatar
gelstudios
whalen rocks!
I bought mine before my mini arrived.
I used the stock **** for about a week before I switched it out.
That was one week too long
The added heft makes shifting smooth, and really easy to get past the Reverse gate/detent.
Old Dec 13, 2005 | 09:25 AM
thefuturequeenofnebraska's Avatar
My Whalen was a dealership installed accessory
Ive never had anything else on my car! i LOVE it!
