Interior/Exterior fastmini.net LED Interior Lighting Kit Install
Took more than a month to get this from Mach V, but I think well worth the wait. They are really bad at answering emails, so give them a call if nothing happens after you place the order. The intensity difference is definitely noticeable. I will take some night shots later, the puddles should look pretty tight. Overall it was fairly easy, although I did not tackle the map lights yet.
You will need:
-A small flat head screwdriver
-Rubber/vinyl/latex gloves - makes gripping the bulbs much easier and if your hands get clammy you won't short out the LED's
-good lighting
Dome cluster LEDs
Dome lighting compared to the OEM footwell bulbs
Puddles were a breeze...
Boot
OEM Glovebox bulb:
Glovebox Festoon Triple LED:
It is very easy to replace the footwell bulbs by just removing the plastic housing around them by twisting the black piece and then pulling the plastic housing off...
Footwell LEDs:
If the lights do not turn on, you just have to rotate the bulb and re-insert.
You will need:
-good lighting
Dome cluster LEDs
Boot
OEM Glovebox bulb:
Footwell LEDs:
--Dan
Mach V
squawSkiBum
Oct 2, 2015 09:21 AM
