Interior/Exterior Boost gauge tap
I purchased an ATM boost gauge. After mounting the gauge and ran the tube to the engine compartment, I realized that the gauge did not come with a T-fitting connector to tap into the pressure regulator. What size connector do I need? Where can I get the T-fitting connector?
_________________
04 IB/W JCW MCS
_________________
04 IB/W JCW MCS
Thank you for the suggestions! :smile:
I purchased the gauges from Summit Racing.
ATM-4301 Ultra-Lite boost/vacuum gauge
ATM-2204 mounting cup
I have 2 gauges, one on each side of the Tach. The mounting cups fit nicely on the small plastic holding the Tach. The only thing I didn't like was the sliver screws contrasting the black of the mounting cup. So I covered it with black screw caps (from license plate screw caps).
The silver face and the red illumination of the gauges match perfectly with MINI's OEM gauge.
There are several aftermarket mounting brackets specifically designed for MINI, but a bit costly, IMO. I figured I could make the ATM mounting cup works and it did.
_________________
04 IB/W JCW MCS
_________________
04 IB/W JCW MCS
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
molala
Oct 2, 2015 01:53 PM
