Interior/Exterior Removing steering wheel trim
Old Mar 12, 2011 | 08:04 AM
TylerF's Avatar
TylerF
Any tips on getting the three trim pieces off the spokes of a three spoke, multifunction wheel? I removed the Torx in the back, but the pieces still seem pretty stuck in place? I assume it's just a matter of prying at this point, but any advice would be great!
-Tyler
Old Mar 12, 2011 | 09:16 AM
MP1.6T's Avatar
MP1.6T
Lots of force is all...
Just work them with your fingers. I pushed on one side from the back of the wheel at times, just using the friction of dry skin. Patience and you will move them a bit, and then get them off entirely. It is just a friction fit.
-Tyler
Old Mar 12, 2011 | 09:51 PM
chaseabryant's Avatar
chaseabryant
I found that it was much easier to get these off when you have the horn pad/airbag unit off of the wheel. You can then just pry them off with a flathead screwdriver. As MP1.6T mentioned, once the screws are off, it is a simple friction-fit.
-Chase
Old Mar 14, 2011 | 10:33 PM
TylerF's Avatar
TylerF
Awesome, that helped. Any tips on removing the grey ring around the aribag/horn?
Old Mar 17, 2011 | 11:19 PM
chaseabryant
unfortunately, you cannot. From what I've heard there is no removing anything from the airbag cover. Many owners have an issue with bending the emblem in the middle of the airbag cover and have been searching for a way to replace it to no avail.
If you are looking to change its color, you can always do a mighty fine tape job OR, you can possibly contact Vinyl Styles about wrapping that little piece in vinyl... I believe I have seen him do it before in red for somebody.
-Chase
Old Mar 18, 2011 | 07:42 AM
TylerF's Avatar
TylerF
I was afraid of that. I think I'll just mask it. Thanks.
Old Mar 18, 2011 | 10:20 AM
chaseabryant
Sure thing! Good Luck (And be sure to share what you do with everybody haha)
-Chase
Dec 23, 2015 10:36 AM
theblackfalcon
Oct 11, 2015 09:49 AM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
