Interior/Exterior Headlight swap possible???
Old Feb 19, 2011 | 07:15 AM
magnat_man's Avatar
magnat_man
Hello,
I have these lights
But would like to get those one
Is it possible? Is it complicated? Will it be a direct plug-in?
Thanks everyone
Old Feb 19, 2011 | 01:43 PM
rkw's Avatar
rkw
People have reported that it is a straight swap.
https://www.northamericanmotoring.co...us-04-mcs.html
http://www.mini2.com/forum/first-gen...yle-lamps.html
http://www.mini2.com/forum/first-gen...ml#post2357210 (post #8)
Old Feb 21, 2011 | 07:49 PM
ninjlao's Avatar
ninjlao
Ninja Mini
If you have the standard halogens and want to go to facelift Xenons you'll have to get the ECU flashed otherwise you'll experience flickering if the car is on. I did the headlight swap myself and a local shop did the flash for me for a 6-pack
Old Feb 22, 2011 | 05:14 AM
yetti96's Avatar
yetti96
"Installation information
For cars built before 09/03, the electronic body module (ZKE) must be replaced (TIS 61 35 510).
After the installation work the retrofit kit must be programmed / coded using DISPlus or GT-1 via the
Retrofit/CIP path."
Also,
But you have an '05 already I had read before the '02-'03 or '04 had a different setup for xenons and possibly different mounting methods. I am no expert on this yet but as I am doing my research and learning more I am not getting a good clear-cut story as to what is what and when the changes occurred exactly.
elverado
Jan 18, 2022 02:51 AM
Kevdog
Electrical
17
Jun 4, 2016 02:20 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
Sterling Thompson
Sep 9, 2015 08:16 PM
tylewis
Sep 6, 2015 07:36 PM
