Interior/Exterior lower dash removal
Old Feb 9, 2011 | 04:43 PM
Brandon_coopers's Avatar
Brandon_coopers
lower dash removal
I have a 2006 mcs and I want to remove or hinge (it appears to be hunged on the bottom) the dash section underneath the steering wheel so I can cleanly run gauge wires. I can't see any screws or anything that would allow me to remove it and other threads talk about removing the whole dash. Thanks
Old Feb 9, 2011 | 05:31 PM
DAVESTER's Avatar
DAVESTER
This is from "A girls guide" how-to ----
Pull down on the knee bolster on the driver's side. To do this, you simply grab the plastic with both hands, in the opening right below the steering column. Give a firm yank downwards, and the bolster will swing down. It is scary at first, because you have to pull kind of hard, but it's OK to do!! YOU WILL NEED TO BE CAREFUL IF YOU HAVE DRIVING LAMPS INSTALLED - when the bolster swings down, it may pull the wires leading to the switch for the driving lamps - so be careful!
Old Feb 9, 2011 | 05:52 PM
Brandon_coopers
Thank you...I was pulling on it to the point where I thought I might break something so I figured id come check to make sure there weren't any hidden bolts that had to be removed first. Seems simple enough.
Old Feb 9, 2011 | 06:08 PM
DAVESTER's Avatar
DAVESTER
Yeah, just grab on and yank it down and to the left a little toward the door. It will pop out and swing down ---
triple5soul
Nov 19, 2019 07:46 AM
eatsleepautox
Oct 30, 2015 06:46 AM
Aug 19, 2015 12:51 PM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
