Interior/Exterior Has Anyone Successfully Installed the new MINI Fini Folding
Old Mar 20, 2004 | 04:45 PM
  #26
zfxr's Avatar
zfxr
Yes, just installed it today. The pre-drilled holes were incorrect from the factory. I had to re-drill new holes into the base. What I did wasn't scientific, but worked. I took two pieces of "fun-tak" for hanging posters on the walls. Put them on top of the rear-spacers, then I screwed the front down (loosely, not tight) to align it properly. When I pressed the plate onto it- voila! It showed up in the exact pattern on the bottom of the arm-rest bracket. Then took the exact center of the blobs, used an awl and it the holes were very closely aligned. I had to elongate one hole just slightly, but otherwise the fit was tight.
The actual holes in the car are about 1" forward of where the pre-drilled holes are
:smile:
Old May 19, 2004 | 07:52 PM
  #27
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
it's not the mini fini armrest but it takes about 10 minutes to install:
http://outmotoring.com/out_motoring_mini_armrest.html
Old May 20, 2004 | 11:38 AM
  #28
norm03s's Avatar
norm03s
Outmotoring, now that is very cool. I will be buying one of these.
:smile:
Alkaidovich
Jan 30, 2021 01:35 AM
flredmini
Apr 5, 2016 06:21 AM
Mini'mon
Aug 26, 2015 01:02 PM
