Interior/Exterior To Dremel. Or NOT... ?
Old Nov 24, 2010 | 02:27 AM
Cudda_Kine's Avatar
Cudda_Kine
If anyone notices. There is one missing switch in the Mini Cooper (Some). The Rear Fog light switch. Is there anything electrical under that portion where the switch is Supposed to be? Thinking about moving my bass **** OR little whistle button there. If there is at least 3 CM of space behind "it". "it" will be possible. Please let me know before so (later today)
EDIT: Right now is 12:28AM
Old Nov 24, 2010 | 02:46 AM
xnotfunkylex's Avatar
xnotfunkylex
There is an electrical panel behind it. not sure how close. But I think that you can go through that part too. Take it apart when it is out of the car. It's pretty easy to do.
Old Nov 24, 2010 | 02:10 PM
Eric_Rowland's Avatar
Eric_Rowland
Pull toggle switch bank (remove downtubes, unscrew)
Disassemble switch bank (just snaps apart, top and bottom)
Drill (better than dremel) hole in blank spot
Then comes the tricky part - access through/around the PCB
There's a thread around here somewhere that demonstrates someone installing their Aux-in port in the empty toggle spot.
Old Nov 25, 2010 | 11:25 AM
Cudda_Kine's Avatar
Cudda_Kine
Thanks people. I took "it" out yesterday, but I didn't have a dremel on me so I'll be doing the work as soon as I get one
willybudista
Aug 15, 2015 06:13 AM
TyrolSport
Vendor Group Buys
21
May 20, 2015 08:02 AM
TyrolSport
Mar 4, 2011 10:50 AM
OctaneGuy
R55 :: Clubman Talk (2008+)
Aug 8, 2010 02:05 PM
Reinheim
16
Jan 17, 2006 09:30 PM
