Interior/Exterior door handle broken
Old Sep 15, 2010 | 01:28 PM
freeskier's Avatar
freeskier
door handle broken
the driver side interior door handle on ym 02 cooper s no longer functions, i must reach out and open the door from the outside. how can i fix this, i have never romoved the inside of the door before
Old Sep 16, 2010 | 10:57 AM
freeskier's Avatar
freeskier
anybody? i just need to get the inner door panel off
Old Sep 16, 2010 | 03:22 PM
Mishka's Avatar
Mishka
It's a several step process.
First, remove the armrest pad. Slide a thin flat object between the pad and the plastic piece its mounted on. There is a tab in there that needs to be depressed, and then the armrest will slide off toward the front of the car. Be careful not to damage the retaining clips at the edgesof the armrest when removing.
Remove small reflector with a prying tool and the screws from the interior panel (three along ellipse of door and one behind reflector).
Go around door trim panel with a plastic prying tool to release panel clips.
Raise door trim panel clear of door lock and relase from top clips by pulling horizontally. Guide door handle out of trim and remove panel.
Reverse process to install.
BEWARE:Trim panel plastic clips are easily damaged and it is recommended to have extra clips on hand before starting. Also, clips are color coded and not interchangeable.
Old Aug 3, 2012 | 04:38 PM
koolmini's Avatar
koolmini
^^^ what about the inside handle repair, do i need to replace a part inside the door?
Old Aug 3, 2012 | 05:01 PM
amazngrace's Avatar
amazngrace
Door handle
Included in these instructions on repairing the window regulator is the 'how to' remove the door panel.
Good instructions with pictures.
http://www.pelicanparts.com/techarti...eplacement.htm
Here is a thread with door handle info.
https://www.northamericanmotoring.co...oor-panel.html
...ED
Old Aug 3, 2012 | 05:17 PM
koolmini's Avatar
koolmini
thanks, i've had the inner doors panels off before (door handles painted)
i just needed to see what i needed to repair the inner handle & the thread you sent me to, was perfect, thanks again
tommorrow i'll pop the panel & re-attach the cable, hopefully that will be all it is & i'll be back in bussiness
R60SX
Sep 23, 2015 09:01 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Southern Marylander
Sep 3, 2015 05:46 AM
