Interior/Exterior Mini/Outmotoring Gauge Panel question...
Old Aug 7, 2010 | 12:36 PM
Haseo461x's Avatar
Haseo461x
So recently I've made some electrical and lighting additions to my mini and after some failed attempts to create a switch box mount under the factory switch line, I've come up with the idea to get the gauge panel and drill 1/2 inch wholes in between the two gauge wholes
I was wondering if anyone had ever done this or if someone could tell me if its possible to drill wholes big enough for switches
Thanks!
Old Aug 14, 2010 | 03:09 AM
Haseo461x's Avatar
Haseo461x
bump need some help people
Old Aug 14, 2010 | 05:13 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is this the panel you infer ?
Old Aug 14, 2010 | 05:22 AM
-=gRaY rAvEn=-
Moderator
If so, that would depend on the switch. Some SPST toggle switches are large in the back, the part behind the dash you dont see. There are three potential areas for room as shown in the photo below. Usually the push button style switches are not so large so that would be the direction I would examine.
I would also have the gauges installed while matching up the switches as well. It could be a really close/tight fit.
Old Aug 14, 2010 | 03:59 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I can't find the picture of it, but I put two radio shack switches (automotive one-way toggles) in mine, one on top of the other in the center to control the gauge dim and on/off. I was having trouble getting my oil temp and pressure to auto dim. They are Cyberdyne gauges. I have to manually dim the gauges, and then turn them off then back on to undim. It is just part of my start up routine. Kind of fun flipping switches.
Old Aug 16, 2010 | 10:43 AM
Haseo461x's Avatar
Haseo461x
yes that is the panel that im infering about
did you just drill them and what is the panel made out of..
also, what'd you use to drill into it with
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
