Interior/Exterior Paint front grill or go mesh?
Old Jul 21, 2010 | 08:28 PM
  #26
TBangin23's Avatar
TBangin23
wow! that turned out really good! and no biggie about the stripes, i had to take mine off. white doesn't stay clean very well as a bonnet stripe. i really like the set you have! i wish they would look good on my cooper.
Old Jul 21, 2010 | 08:29 PM
  #27
TBangin23's Avatar
TBangin23
Originally Posted by -=gRay rAvEn=-
woah! gray raven! thats SHARP LOOKING!
Old Jul 22, 2010 | 01:20 AM
  #28
s2kjay's Avatar
s2kjay
i plasti-dippd my grill a couple months ago and theyre holding up just fine. i did a good amount of coats to insure a nice finish. i also did the headlight rings, door handles, gas cap, emblems and side scuttles. all holding up fine. here are some pics:
http://www.flickr.com/photos/52066248@N08/
Old Jul 22, 2010 | 06:55 PM
  #29
TBangin23's Avatar
TBangin23
well. just did my grille with the plasti dip today. turned out pretty good i think. only thing is i had to touch up a few spots. no biggie. should i put a few more coats on? i only did two. take a lookie!
Old Jul 22, 2010 | 07:02 PM
  #30
bradklodowski's Avatar
bradklodowski
Originally Posted by TBangin23
okay, so how do i get the top grill off?
I didn't unscrew mine. Then again mine may be different because I have an R53 Facelift. I don't know offhand if that's the case.
Anyway, I carefully snapped out all of the plastic tabs that hold the grille into the backer assembly. I used a few flatbladed screwdrivers on the tabs to pry them out. It took awhile mainly because I was afraid of breaking something at first, you will need to be careful but firm.
I was too chicken to try to take off my headlight rings, so I masked and sprayed those in place. I have a great way to do that, if anyone's interested.
Old Aug 5, 2010 | 09:57 AM
  #31
jwilslifeismusic's Avatar
jwilslifeismusic
yes how?
Old Aug 5, 2010 | 10:38 AM
  #32
dannyhavok's Avatar
dannyhavok
I'd like to hear this headlight masking trick as well!
Old Aug 9, 2010 | 05:34 PM
  #33
luseboy's Avatar
luseboy
mesh
Cavalier,
look at my signature. I bought my r53, and it came with a mesh grille on it. I think it is actually something one of the past owners (im the 6th) got from a hardware store, and bent it to fit in place of the lower grille. Sounds sketchy, but it actually looks really cool if you ask me. Then again, i do have a black car. but you might consider this, as a vastly cheaper option, and you might even be able to find a black one, if not, painting that stuff is no problem at all. i can take more pictures and what not if youd like.
-Austin
Old Aug 10, 2010 | 04:22 AM
  #34
Haseo461x's Avatar
Haseo461x
the look of the aero grille is a lot more different then you would think. at least that is what my conclusion is.
i got mine from moss and when i got it i was kind of mad because it was a gloss finish but it ended up looking great.
id suggest lookin at other minis in person that have the mesh and see what you like. i know im sure youve seen pictures but its best to see in person.
also, with the mesh, it makes it look a lot more unique i think simply because the grille is, afterall, a different grille.
boostedhaze
Jan 2, 2018 07:26 PM
wkp1219
Nov 13, 2015 07:52 AM
dcrna1
Aug 19, 2015 01:30 PM
FLYM1N1
Aug 15, 2015 11:20 AM
