Interior/Exterior How to remove gas lid on a justa?
Old May 2, 2010 | 08:46 AM
ammodave's Avatar
ammodave
I'm considering converting to the Cooper S chrome gas cap on my justa (I like chrome) but I can't quite figure out how to remove the oem gas lid. I did several searches here but I'm still in the dark. Anyone know how it's done?
Old May 5, 2010 | 07:37 AM
ammodave's Avatar
ammodave
Surely someone out there knows how to do this. I've found directions appropriate to the Gen 1 but the housing on the Gen 2 looks a little different. Help anyone?
Old May 5, 2010 | 11:29 AM
JJUK's Avatar
JJUK
Here are instructions by RVW from the Mini2 Forums:
Fitting Instructions
1. Jack up and remove wheel.
2. Chock under the hub and ease the car down onto it so the weight is off the car jack.
3. Remove the black plastic screws and their surrounds from the cover behind the wheel.
4. Remove 2 plastic nuts from the cover behind wheel.
5. Remove 1 self tapping Torx screw from the bottom of the wheel arch at the front of the rear wheel.
6. Remove steel nut holding filler to bodywork underneath wheel arch.
7. Remove steel nut holding filler tube to bodywork underneath wheel arch.
8. Lift the filler tube over the stud that held it to the bodywork.
9. Open the filler cap, remove black cap, push the filler inwards into the wheel arch, you may have to wiggle the filler at the same time.
10. Remove the filler locking mechanism.I used the torx screwdriver to rotate the black plastic grommet anti clockwise 1/4 turn, then pull itfrom the rubber gaiter underneath. It may be best to lock the car so that the filler lock plunger moves further in. I didn't do this and ended up losing it inside the bodywork for some time!
11. With your left hand put your fingers into the noe empty filler hole, find away underneath the rubber that seals it between the filler pipe on the right hand side and give it a tug outwards and to the front of the car at the same time, hopefully it will pull off one of the little clips that holds it to the bodywork.
12. Remove the old filler cap
13. Put the new filler in position, before clipping it fully, make sure it fits over the locking plunger, then place the plastic grommet and rubber gaiter over theplunger and clip into place, the push onto bodywork.
14. This is the hard bit...push the filler pipe back onto the stud on the side of the bodywork, after I did this the filler spout fell into place in the the rubber seal on the filler cap. Believe me you will not regret chocking the car at this point !!!
15. Once the filler is in place, remve the rubber lanyard from the old black filler cap where it slots into the old filler, and replace on the new filler cap.
16. Fit new plastic trim into bodywork. ( You will have to have this painted to match your car) It just clips in. Be CAREFULL when you remove the old one as you may scratch the paintwork YOU HAVE BEEN WARNED
17. Refit the 2 steel nuts underneath the wheel arch, then re-attach the wheel arch cover, the 4 black plastic screws just push in this time, the 2 plastic nuts and 1 self tapping torx screw.
18. Don't forget to put your wheel back on, doesn't drive well on 3 wheels
The above have been copied from some one else who for the life of me I cannot remember, SO thanks to whom ever it was.
The only thing I found that made life a bit easier was to use a bit of silicone spray on the rubber to allow it to slide easy.
No responsibility is taken by me or the original writer of these instructions if you cause any damage to your vehicle when carrying out this mod
Hope this helps.
Old May 6, 2010 | 07:45 AM
ammodave's Avatar
ammodave
Thanks for the tutorial; I'll give it a try before I invest in the conversion bits.
Old May 7, 2010 | 12:30 PM
ammodave's Avatar
ammodave
Well, I removed the inner fender panel to give this procedure a try. I can get the filler tube off but the procedures above don't really address removing the door and its housing. Once the filler tube is removed the door is still held firmly to the bodywork. There must be some steps missing.
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
greekzilla
Aug 23, 2015 03:44 PM
Herleman
Aug 16, 2015 06:41 PM
speedbird_1
Aug 15, 2015 04:44 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
