Interior/Exterior manual rearview mirror to autodim mirror possible?
Old Feb 18, 2010 | 12:09 AM
emans's Avatar
emans
I have jst the regular mirror witht he manul button that flips it for night. I would really want a autodim mirror, is there any way I can buy one and hook it up? Any thoghts?
Old Feb 19, 2010 | 07:56 AM
schatzy62's Avatar
schatzy62
It may be possible but only if the wiring harness for the auto mirror is in the car. If it is not then there would be a lot of extra cost in adding theh siring needed.
Old Feb 27, 2010 | 04:53 PM
MLPearson79's Avatar
MLPearson79
I'd like the answer to this myself...let me know if you figure it out!
Old Feb 27, 2010 | 05:38 PM
rkw's Avatar
rkw
The mirror with autodim (and also the Homelink garage door opener) should be a self contained unit because it doesn't interact with the rest of the car. Therefore I believe all it needs is power. The wiring diagrams seem to agree with this. It shows the mirror having only two connections, coming from the fuse/junction box. If the car isn't prewired for the autodim mirror, I would look for another switched power source in the dome light/switch area.
Old Feb 28, 2010 | 05:08 AM
amusingdream's Avatar
amusingdream
you could also just tint the back window.
Old Mar 4, 2010 | 04:53 AM
richardsperry's Avatar
richardsperry
Usually autodim mirrors need power, ground, and a signal form the transmission reverse light.
The reverse signal keeps the miror from dimming when you put the car into reverse. (duh)
I added an autodim/homelink to my 95 BMW and had no issues. I havem't looked at the Mini, since t already has autodim. Now if we could only get the outside mirrors to dim, like my old Audi...
Old Mar 4, 2010 | 09:13 AM
rkw's Avatar
rkw
Ah, that makes sense. The wiring diagrams show the mirror connected to power (fuse F25), ground, and a connection to the junction box that the diagram doesn't trace further back. It would be logical if the third wire is the reverse light.
khumpert
Nov 30, 2015 11:48 AM
dyeLucky
Sep 11, 2015 10:41 AM
Powershift
Aug 16, 2015 05:14 PM
dyeLucky
Aug 7, 2015 07:10 AM
