Interior/Exterior Dealer installed driving lamps...how much?
For those of you that had the dealer install driving lamps on your MINI after purchase, how much did it set you back? I got a coupon from MINI in the mail for 10% off dealer installed goodies so I'm wondering if I could use my tax return on the lamps I've been drooling over since I brought her.....thanks
on
See if it's cheaper to order off Morristown MINI's site and have the dealer install. The install manual says 1.25 hours.
Just a side note; I've looked at the driving lights on cars on the dealer's lot and the holes they cut into the grilles are typically pretty crudely done, at least at my local dealer. It would bug me to have my grille chopped up they way they do it. Check out your dealer's cars with driving lamps and see if this would bother you at all.
The Driving Lamps come with a NEW grill with the cutouts for the lamp brackets.
If a dealer had CUT a grill to install them, I would be reluctant to use that dealer for anything!
The lights are pretty easy to install, the wiring is pretty straight forward if you have the knowledge.
I would think about 150-200 for an install charge would be the going price at most dealers.
On the MCS Grill however, don't buy the MCS Grill, it won't fit, the JCW Grill is the one that will fit our MC's. I've priced it at outmotoring.com for $55.95, haven't gotten a quote from the Dealer on installation, but I'm thinking about 1/2hr. Labor.
I will be getting that and the Chrome Line Exterior Lower Grill Trim installed on April 19th.
Good Luck on your Mods, we'll be L@@KING for pics!!
You will need the following 3 items...
Driving Light Kit - which includes the wiring
Installation Kit - which includes the brackets and NEW grill. if you have a JUSTA, specify the JCW grill for a JUSTA. it will have the cutouts.
Switch - this is a color coded piece inside your car with the switch attached. mine is rooster red, like my interior.
The FULL retail price for all three parts is 464.00
Morristown MINI is 394.83, which is 15% off
Go to your dealer and ask for 20-25% off, they WILL give it to you. Most all do if you bought the car from them. even if you didn't and you service your car with them, they will. If they don't, call Morristown and ask them for a little better price. They are usually VERY good about helping you out.
Now Installation...
I have the Insatllation Bulletin and it takes 1.25 hours.
So @ 1.25hrs @ a rate of 100.00 an hour = $125.00 USD
I would shoot for a price of 375.00 for the lights and 125 to install for a TOTAL of 500.00 INSTALLED!!
I have installed 2 sets of them, one in an '09 and one in a 2010. The second one took me NO more than an hour and a half.
Good luck, just don't let them take advantage of you, it sounds like they are for 900-1000.00, proof is in the numbers!!
You can PM me if you want and I will email you the Instruction Bulletin that shows you how to install and the time it takes.
Now Installation...
on
The install sheet may say 1.25 hours, but don't expect any dealer to do it for that rate. I called two in my area and both wanted over $350 for the labor. All of the required parts cost me $400. So I just installed myself. The wiring was the easy part. The hard part was removing all the trim and routing the wiring harness through the firewall. It is cramped in there. I'm glad I did it but it took me about 6 hours to do. Now that I have done it, I can probably do it in three.
I highly recommend the lights though. They are awesome.
I've been looking at the same thing. I find the lights themselves cost about $300, the installation kit costs another $110, and the interior pieces including the switch and the little replacement dashboard piece costs about another $70, so plan for about $500 in parts. If you can do the work yourself, you will save another $500 approximately in labor costs. Installation looks to be straightforward, expecially if you are not as fat as me and can fit yourself uncer the dashboard for a few seconds.
have you considered other than factory?
these brackets from outmotoring allow you to use a generic set of lights which are very easy to wire....you just won't have a factory toggle . . .
http://www.outmotoring.com/mini-coop..._brackets.html
you could do the whole job for $200 and a couple of hours of play time.
Another option is VIP Custom Parts, http://www.vipcustomparts.com/minicooperparts.htm
They make some nice driving light kits.
minicoclub
11-11-2015 07:25 AM
squawSkiBum
10-02-2015 09:21 AM
