Interior/Exterior Remove paddle Shifters to install JCW wheel?
Old Jan 13, 2010 | 09:29 PM
  #26
The QZ's Avatar
The QZ
Originally Posted by rkw
By your description, the MFSW and paddles both have wires going into a single connector. You can probably just remove the pins that belong to the paddles. A pin can usually be removed from a connector by pressing on a tab that releases it.
How exactly are you using it now? The MFSW and paddle pieces not installed and off the car? A closeup pic of the connector may help.
Right now I have the mfsw controls plugged in, however they are not getting power. There are two open plugs that should go to the paddles. I could try removing those pins, from the harness, but I'm not sure if that would solve the problem. I think, that the way it's wired, the circuit is not closed without the paddles connected.
A harness that is wired to not have the paddles should work, unfortunately you can't order the harness alone. I guess it could be re-wired if you knew what you were doing.
Old Jan 13, 2010 | 10:39 PM
  #27
rkw's Avatar
rkw
Originally Posted by strobeyprobey
If you look at this page it shows WAY more part numbers for the "switch unit steering"
http://www.europartsamerica.com/partnumbers//mini1.htm
I don't see anything that's not on RealOEM. Try looking up those part numbers on RealOEM. If you search "switch unit steering" on RealOEM for R56 Cooper S, it returns 24 results. The only variations I see are for rain sensor and DSC (none for auto paddles).
Old Jan 14, 2010 | 07:41 PM
  #28
The QZ's Avatar
The QZ
Success!!!!
With the MFSW buttons and harness for the manual it worked!
So it seems as long as it is the wiring harness for the manual it works fine.
So any auto people that wanted a special steering wheel (JCW, redwood, tuscan, hot chocolate), but were told no because of the auto you can now do it without having to modify the wheel for the paddles. So as long as you're ok with not having the paddles you can easily do this. All you need is the MFSW module with a wiring harness meant for manuals.
Unfortunately, that part is a bit pricey. $200 bucks for the module and harness. And there is no way to order just the harness, there is no part number for it.
I'm still glad I did it, the JCW wheel feels so nice in my hands.
Pics tomorrow I hope.
Old Jan 14, 2010 | 08:00 PM
  #29
strobeyprobey's Avatar
strobeyprobey
OH EXCELLENT!!!!! I am so happy for you! Do you have the part number you did get available to post? Obviously you can't completely trust RealOEM because it did not show a different part number.
Old Jan 14, 2010 | 11:41 PM
  #30
The-Only-One's Avatar
The-Only-One
Congrats!
Hope to see some pics soon. I fear you might want to change the look of the A/T shifter to a manual one as well
Rather than spending an add'tl 200$ on a part I already have, I'll try to upgrade a JCW wheel to a paddle'd one. IMHO, worth a try Just my two cents...
Old Jan 15, 2010 | 12:16 PM
  #31
The QZ's Avatar
The QZ
I'll post the part number from the box when I get home.
Well, I won't get a manual shifter, but it can be done if you wanted too. You would lose the locking part of the shifter which is bad if you accidentally knock the shifter from D to R or P! I did get a new auto shifter though. MINI actually makes a JCW alcantara shifter for the autos. It matches perfectly and goes well with my alcantara shift boots from redline.
As far as modding the wheel to accept paddles...it's up to you. It would involve cutting and drilling into a $500 wheel which I'm not comfortable with. I got my wheel for $250 so the extra $200 for the controls makes it a wash for me.
I'll have pics later tonight.
Old Jan 15, 2010 | 06:01 PM
  #32
The QZ's Avatar
The QZ
The part number for the mfsw switches is 32309200098.
Here is a pic:
As you can see, it's a JCW steering wheel with an auto. You can see my JCW shifter there too. I need to take better close ups, there was too much light.
Old Jan 19, 2010 | 10:17 AM
  #33
strobeyprobey
32309200098 Someone has them for $95 on eBay now!
So for the original poster wanting to ADD the paddle shifters, they will need the steering wheel, new MFSW controls (part number unknown, as there are two other options on RealOEM), and the paddles themselves. (As long as the socket for the paddle shifters is available on the steering column)
Old Jan 19, 2010 | 11:36 AM
  #34
drewstermalloy's Avatar
drewstermalloy
The wheel, besides being the JCW, looks way better without the paddles. Well done.
Old Mar 2, 2010 | 10:15 AM
  #35
Red-Mini's Avatar
Red-Mini
I want ot paint the Multifunction buttons on my steering wheel - can the 3 silver covers on the steering wheel be removed form the front of the steering wheel for paint or do you have to take the steering wheel of of the car
Old Mar 2, 2010 | 05:46 PM
  #36
The QZ's Avatar
The QZ
They can be removed without taking the wheel off. The center one just pulls off, it's just held on by friction. The sides require the removal of one torx screw each(T20 I think) and then it's just friction. The silver covers separate from the button assembly.
However, it is much easier to do the job if you remove the wheel.
Old Mar 3, 2010 | 07:05 AM
  #37
Red-Mini's Avatar
Red-Mini
Paint Multi finction buttons
where is the torx screw located - I am afrain to play with the airbag
Old Mar 3, 2010 | 08:12 AM
  #38
The QZ's Avatar
The QZ
There are two. One behind each button panel. Just feel for them with your fingers. You'll find them.
Old Jun 30, 2010 | 05:51 PM
  #39
SSr56's Avatar
SSr56
I just followed your instructions an upgraded my steering wheel as well . It's really simple, I don't know why MINI can't offer this from the factory for us autos. I have the all leather version any tips on how to keep it looking like new?
Old Jul 2, 2010 | 12:10 AM
  #40
Sketch's Avatar
Sketch
Keep the leather clean and conditioned with some leather products, I prefer the ones from Meguiar's.
Old Jul 7, 2010 | 04:51 PM
  #41
Arnel's Avatar
Arnel
Any pics? I'll be looking to do this too.
Old Jul 7, 2010 | 04:56 PM
  #42
SSr56's Avatar
SSr56
Actually, I took it off because I decided to sell my car. If anyone is interested I'm selling my steering wheel with the required multifunction buttons for it to work with the auto. It's in the market.
Old Jul 7, 2010 | 05:07 PM
  #43
Arnel's Avatar
Arnel
Sorry I ordered the parts already.
rckrzy1
Aug 11, 2015 06:06 PM
nomar116
Aug 10, 2015 11:24 PM
jcb-memphis
Aug 8, 2015 11:09 AM
