Interior/Exterior Gear knob and hand brake lever 2003 CS
Old Jan 25, 2009 | 12:26 AM
Mike S's Avatar
Mike S
Gear **** and hand brake lever 2003 CS
How do you remove the gear **** off a 2003 Cooper S? I ordered a JCW CF **** and hand brake lever from New mini stuff. I would prefer to know what the details are before tackling this and perhaps breaking an important clip or something.
Same goes for the hand brake lever.
PS. Also if there are anything special I need to know about removing the down tubes, please let me know
Thanks much in advance!
Old Jan 25, 2009 | 12:37 AM
xnotfunkylex's Avatar
xnotfunkylex
For the shift **** just pull really hard in an upward motion. And I do mean hard.
E-Brake handle: the **** on the end of it pulls straight off and then there is a tab underneath that you will need to pry off and then it will slide off. I think you will need to take the boot off as well but I can't remember. If you do need to it is clipped in around the bottom along the trim piece/cup holder.
Old Jan 25, 2009 | 01:10 AM
MrCooperS's Avatar
MrCooperS
Moderator
As a tip...if you have a sunroof, open your sunroof before you take of the gear ****...
Old Jan 25, 2009 | 01:44 AM
Mike S's Avatar
Mike S
LOL! Thank goodness I ordered the car without that option
Thanks so much! Wish me luck.
Old Jan 25, 2009 | 02:19 AM
MLPearson79's Avatar
MLPearson79
+1, and watch your teeth...when it comes off, it's scary!
Old Jan 25, 2009 | 04:03 AM
4Boogie's Avatar
4Boogie
all throttle no bottle
if you put a flathead screw driver between the bottom of the **** and the lip it rest on and give it a twist it pops loose without all that pulling
Old Jan 25, 2009 | 04:05 AM
4Boogie's Avatar
4Boogie
if you put a flathead screw driver between the bottom of the **** and the lip it rest on and give it a twist it pops loose without all that pulling. You need to get yourself a Haynes manual
sevin
May 2, 2026 06:11 AM
kurosh
Aug 27, 2015 11:54 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
