Interior/Exterior I installed the MINI Cooper Euro center armrest
Old Dec 19, 2008 | 05:21 PM
  #26
ricbow's Avatar
ricbow
orderd one on monday 12/15
Old Dec 20, 2008 | 06:44 AM
  #27
JCR1960's Avatar
JCR1960
Originally Posted by paulsminis
TIS=Technical Information System, which is the BMW/MINI CD repair/installation manual the dealers use.
Great and thank you for explaining the meaning of it
Old Dec 20, 2008 | 06:50 AM
  #28
JCR1960's Avatar
JCR1960
Excellent
If you need any tips on the installation or which Torx size bit socket to use to remove the seat rails the information is in this thread and always feel free to ask any questions that you may have.
Old Dec 21, 2008 | 09:57 PM
  #29
PoktRokt's Avatar
PoktRokt
Has anyone figured out a way to stop the usa version from always sliding open?
Old Dec 22, 2008 | 08:22 AM
  #30
JCR1960's Avatar
JCR1960
Some have posted that they had it replaced under warranty to correct it from sliding open when leaning on it.Now whether or not the replacement one does the same thing I do not know though.
Old Dec 22, 2008 | 12:24 PM
  #31
geekswrath's Avatar
geekswrath
Does the Euro armrest rattle any? My stock has started to and it's driving me nuts.
Old Dec 22, 2008 | 01:22 PM
  #32
Doug W's Avatar
Doug W
This worked out great for me. Simple, cheap, and effective.
See post #38.
https://www.northamericanmotoring.co...-closed-2.html
Old Dec 22, 2008 | 06:56 PM
  #33
JCR1960's Avatar
JCR1960
Not at all plus it is firmly bolted to the left and right back seat rails where the factory armrest is attached to the back of the center console.
Old Dec 23, 2008 | 12:04 PM
  #34
Greg Davis's Avatar
Greg Davis
Caution - HiJack Alert!
I had a loaner yesterday with the factory armrest and noticed that when folded up, it is not perpendicular to the floor, so it got in the way of my arm.
I saw a comment on here about the "Euro" version having the same problem.
Are there ANY armrests that fold completely up out of the way?
HiJack off!
Old Dec 23, 2008 | 05:30 PM
  #35
JCR1960's Avatar
JCR1960
HiJack off!
I guess it all depends on how long you right arm is.
Honestly I believe all of the center armrests for the Mini Coopers will intrude a bit when folded up,some more then others.Although there may be one designed out there that doesn't.
Old Dec 23, 2008 | 05:45 PM
  #36
ricbow's Avatar
ricbow
it's the 23rd,got my euro arm rest today.20mim install really happy thanks minispeed
Old Dec 23, 2008 | 06:11 PM
  #37
JCR1960's Avatar
JCR1960
Excellent!!
Old Dec 23, 2008 | 09:02 PM
  #38
ricbow's Avatar
ricbow
any one going to minis on the dragon?
Old Dec 29, 2008 | 11:23 AM
  #39
TsPoet's Avatar
TsPoet
Pilot,
I just ordered some Wet Okole seat covers - so please tell me how you did the lovely arm rest cover.
I can order an extra 1/2 bolt of cloth from Wet Okole to do the same - but I'm not crafty in any way.
thnx.
Originally Posted by pilotart
Old Dec 29, 2008 | 11:45 AM
  #40
AKIndiMini's Avatar
AKIndiMini
I've got the Euro arm rest on my R53 - I love it, with one minor exception...I wish it would raise a bit higher. It's still in the way when in the UP position.
It was easy to install, does not rattle, holds a bunch of stuff, and the lid does not pop open.
Old Dec 29, 2008 | 08:55 PM
  #41
pilotart's Avatar
pilotart
Super Comfortable Armrest
Originally Posted by TsPoet
Pilot,
thnx.
Really easy job, the Wet Okole Material has a huge amount of 'stretch' built in.
With the Euro Armrest lid open, you will see six phillips head screws to remove and the existing padded part comes off.
The existing leatherette padded cover is just held in place by 'double-stick' and can be easily removed.
For my 'padding' I was using Memory Foam and first effort seemed a little sparce for me
(see my Gallery photo dated 07/23/2008;
this had been 3/4" x 4" x 11" Memory Foam over the existing padded cover material).
Job that pleased me started with 2 3/8" x 4 1/2" x 12" Block of 5 Lb Memory Foam alone.
Memory Foam is expensive and hard-to-find, I went to a local Custom Foam Shop
and bought what I needed (a lot) from their 'remenant' pile.
You place this foam block in the freezer for twenty minutes and then you have about a minute of very stiff material
that a 60 grit power sander can easily round the edges and corners.
(An Electric Carving Knife or a Band Saw or Jig Saw also make excellent tools for cutting and trimming foam,
never tried a 'hot' wire, but it may work as well by using some coat hanger in your Soldering Gun.)
I then used a little adhesive to hold it 'still' on the pad frame.
To attach the Wet Okole cover, I used Weldwood Contact Cement, you coat frame and material
and then wait 15 minutes+ (less than two hours) and then where it touches, it sticks.
Given the resistance of the Foam, I felt that the old 'double-stick' was not sufficent adhesion.
The two long sides were fastened first and then the ends were gathered, stuck and trimmed
(You can look at the old Leatherette cover and see how they made the 'V' cuts inside at the corners,
be sure to trim enough to fit the padded part back into the lid).
Those six Phillips Screws need to be started while you apply hand pressure to hold the frame to the Lid,
then draw those screws tight and you are done!
Old Dec 29, 2008 | 10:24 PM
  #42
mini on's Avatar
mini on
Santa got me mine
Old Dec 30, 2008 | 03:41 PM
  #43
Moltenmini's Avatar
Moltenmini
Warranty fixed my slidy american one, same damn thing but it is less slidy. As time goes by I am sure it will crap out and I will go for the euro one. looks real nice and I can stash my weed in it.
Old Dec 31, 2008 | 06:03 AM
  #44
JCR1960's Avatar
JCR1960
Originally Posted by mini on
Santa got me mine
That is great to hear
That is what happened on my former '08 MCSa I told my SA that the lid on the factory armrest keeps sliding back and he said the replacement one will end up doing the same thing.What is nice about the Euro armrest is that it has a latch in front to keep the lid closed.
Old Jan 8, 2009 | 01:59 PM
  #45
jhbjrpdx's Avatar
jhbjrpdx
Got my late Xmas present today: the Euro Armrest from Minspeed. The package got a little lost on a malfunctioning UPS railroad flat car somewhere.
It went in pretty easily and I like it. I was worried how it would effect my shifting hand but I don't have to adjust much at all. Extra storage is nice and it is very sturdy. I am glad I decided to forgo the factory version which didn't entrall me during the test drive.
Old Jan 9, 2009 | 04:47 AM
  #46
JCR1960's Avatar
JCR1960
It went in pretty easily and I like it. I was worried how it would effect my shifting hand but it don't have to adjust much at all. Extra storage is nice and it is very sturdy. I am glad I decided to forgo the factory version which didn't entrall me during the test drive.
Congrats and great to hear that!!
Old Jun 4, 2009 | 09:45 AM
  #47
bonehead04's Avatar
bonehead04
Don't know why, but after driving my Mini for 2 weeks, I finally noticed the lack of a center armrest on the way to work this morning. I was all fidgety b/c I didn't have a place to put my elbow
Glad I found this thread. Big problem now is that Mini raised the price of this thing to $260! Absurd....but I'll probably end up getting it as I've read elsewhere that the aftermarket ones have some other issues I don't want to deal with.
Question about the install: Do you have to use a ratchet torx driver or is a regular torx screwdriver okay? From the pics, it looks like it'll be okay as long as I have an extension.
Old Jun 4, 2009 | 09:54 AM
  #48
AKIndiMini's Avatar
AKIndiMini
I ended up using a 3/8" drive torx driver with an extension. The bolts were on there too tight for me to undo with a torx screwdriver.
Old Jun 4, 2009 | 12:07 PM
  #49
ricbow's Avatar
ricbow
+1
Old Jun 7, 2009 | 09:25 PM
  #50
MNIMEJCW's Avatar
MNIMEJCW
I am very happy with my Euro Armrest,
glad I avoided having to first remove a MINI-USA version and replace the rear half of the console.
I found that the Euro Armrest sloped too far down for my comfort,
likely set to allow minimum interference with Manual Shifter,
but this causes more interference with the parking brake.
I first experimented with a 'rubber' wine cork, seen held with yellow tape in this photo:
Click <HERE> to open a high resolution version of above photo in a new tab/window
and then click on that photo to expand. Click <HERE> for photo of 'down' position.
I have since done away with the tape and used Contact Cement to attach that 'cork' to rear of armrest.
I found that the rubber wine 'cork' placed the armrest at exactly the height I wanted
and had a nice 'springy' feel to it.
You could experiment with various 'bumper' materials and sizes using tape first
and then cement to backside of 'bin' and have it out-of-sight.
Thanks for your post. I thought the arm rest lacked something. But I never though it would be this easy to change. I did mine in about 15 min or so at a cost of $3.52 in vinyl found at a local fabric shop. What a difference it makes.
After
Before....seems to lack some "pop"
