Interior/Exterior Alta gauge issue
Old Dec 7, 2008 | 05:10 PM
ANT818's Avatar
ANT818
Alta gauge issue
Just finished installing both the Alta water temp & boost gauges. One small problem. The diasy chain lead is not long enough. The wire was nearly impossible to install. Finally I got the wire attached in order to test. In order to get the wires connected I had to move the pod to the highest position next to the tach. I measured both daisy wire that were shipped, they're both the same length. I think I need about 4 inches more. I could probably live with a little less but it would be really difficult to remove it once installed.
Anybody know where to get another wire with the correct ends?
Old Dec 7, 2008 | 05:33 PM
iwashmycar's Avatar
iwashmycar
subscribing. my gauges are in the mail...
Old Dec 7, 2008 | 07:11 PM
drsilvermini's Avatar
drsilvermini
try calling alta or sending them a pm on here
Old Dec 20, 2008 | 03:10 PM
spfdhed's Avatar
spfdhed
Actually if you call prosport in St Pete (google it) they have been very responsive to all my questions and needs for their gauges (despite the fact that I purchased through Alta). They will likely send you a longer lead. I had the same problem and had an extra daisy chain and I spliced two together to give me enough play to lower the gauges.
Old Dec 23, 2008 | 05:20 PM
iwashmycar's Avatar
iwashmycar
i just spliced both of the wires togeather under the dash and ran single wires to the power/ground/ect. Basically i didnt jump from one gauge to another... no biggie
Old Dec 24, 2008 | 11:12 AM
LONO's Avatar
LONO
Mine was to short also. Have to keep my gauges in the lowest position for them to work. Screws are the wrong pitch also so they will not stay tight. As a result I just keep them at lowest point anyway.
Old Dec 24, 2008 | 12:23 PM
iwashmycar's Avatar
iwashmycar
as for the screws.... swap the tach screws with the ones that hold on the OBD2 port.... works great
Old Dec 24, 2008 | 04:27 PM
JAceMin's Avatar
JAceMin
Odd, I had this same problem like 6 months ago when I installed my gauges, I called Alta, they said they were aware of the issue and would be addressing it in coming releases. In fact there is a post here by me discussing this, where they claim they fixed it.
I fabricated my own harness, looks like that is still the fix.
Old Dec 24, 2008 | 04:34 PM
JAceMin's Avatar
JAceMin
Aaah, yes found the ref:
my rant post :
https://www.northamericanmotoring.co...y-on-mods.html
Originally Posted by ALTA2
I too am sorry about all your experiences with us. There are some issues there that are not excusable. But i do believe you talked to me about the harness being a little short. I explained how we hadn't see that issue but we could get a harness that might be a little longer. You said you just spliced the wires to make it work because of time. I (while we were on the phone 7/17) sent an email to Prosport explaining how your harness was short. He told me he was looking into it with the factory and would get that taken care of.
Old Dec 24, 2008 | 09:41 PM
LONO's Avatar
LONO
Thanks for the tip I will give that a shot.
Old Jan 4, 2009 | 05:16 PM
ANT818's Avatar
ANT818
i also spliced. I tried calling prosport. They didn't return my call. So much for good customer service. IMHO there's no excuse for Alta. Shame on them if they didn't do an install before shipping the guages. If they did, shame on them for not making the $2.00 correction. It's the little things that separate a good company from everyone else.
Old Jan 6, 2009 | 03:01 PM
ANT818's Avatar
ANT818
update:
When the headlight switch is "0" the gauges do not power up. I'm thinking the lead that Alta suggested to splice off of the OBD was incorrect. It does power up with the headlight switch in either of the other 3 positions.
Old Jan 6, 2009 | 03:03 PM
scott48's Avatar
scott48
I followed Alta's instructions and my works fine....turns on when i fire up car, and then switchs colors when i turn the lights on.
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Chasp
Sep 4, 2015 09:31 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
