Interior/Exterior Removing Tail Lights on an R56.
Old Feb 3, 2009 | 02:42 PM
  #26
Sketch's Avatar
Sketch
Originally Posted by mzangari
Just finished this....got the new tail lights from classic mini(thx paul)....it toook all of 10 minutes to complete both.....one note - check the middle(blinker) bulb in your new tail light....mine had the white cover but an amber bulb...so I took the stock bulb out which was white(go figure)....very easy mod and IMO, looks nicer than the amber tail light flashers....good luck all and thanks for your help!
Might want to check the legality of having white rear turn signals... To get the clear look I would suggest some chrome plated bulbs, and not stock white bulbs.
Old Feb 3, 2009 | 03:23 PM
  #27
mzangari's Avatar
mzangari
thx
Sketch...you are correct...i just checked and where i am(NJ), you must have amber or red bulbs for rear turn lights...I think different state have different laws..oh well....now I know why they came with the amber bulbs... Don't tell anyone but I'm gonna press my luck and leave the white bulbs...yes, I am bold and crazy...HA!!
Old Feb 3, 2009 | 07:04 PM
  #28
Sketch's Avatar
Sketch
Good luck man... Id be a little weary of someone thinking there reverse lights! But the look is pretty gnarley
Old Feb 17, 2009 | 10:31 AM
  #29
enron29's Avatar
enron29
So has anyone determined whether the tail lights can be pried apart to remove the orange lens and replace it with a clear lens? Is it similar to the headlight where it just needs to be heated up and pulled apart. If anyone has any information, please pass it along. Thanks.
Old Apr 17, 2009 | 09:45 PM
  #30
asaulo1's Avatar
asaulo1
I tried this tonight and for the life of me, I could not get the tail light assembly off. It looked like it was getting caught at the bottom. I was able to find the tab at the top of the light and was able to get the top halfway out but not the bottom. I was scared that I was going to break something if I popped it off with some force. I don't remember this being that difficult on the R53. I just gave up and reassembled everything back. I was trying to get the minspeed rear fog light to 3rd brake light conversion done.
Old Apr 18, 2009 | 01:18 PM
  #31
ashboomstick's Avatar
ashboomstick
Make sure you pop the two tabs that are on the inboard side (towards the center of the car) first. You should be able to release 1 or maybe two more then just pull/rotate it off.
Old Apr 18, 2009 | 02:14 PM
  #32
Oxybluecoop's Avatar
Oxybluecoop
Old May 1, 2009 | 05:51 AM
  #33
jbewley's Avatar
jbewley
Originally Posted by OXYBLUECOOP
Thanks. Now I know there is a retaining clip at the bottom. Releasing the top on is easy, but I can't seem to find the relaese point for the bottom one.
On all the mods I've done the instructions merely say "disconnect plug, wire, clip, etc". They never say "disconnect by pressing down on small tab and then rotate the locking lever 90 degrees to the rear" or "disnonnect AUX Jack by pressing the two side clips, then push unit out the front, twist sideways and pull back through the opening" which would be very helpfull.
Jim
Old Jan 15, 2013 | 07:09 AM
  #34
Mini0n's Avatar
Mini0n
I dont know how is still looking at this thread but this guy took his taillights completly apart
https://www.northamericanmotoring.co...aillights.html
Old Jan 15, 2013 | 07:15 AM
  #35
Mini0n's Avatar
Mini0n
big typo! If any of you are still...etc
Sexual Chocolate
Mar 31, 2019 08:02 PM
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
