Interior/Exterior Removing center console?
Old Aug 19, 2008 | 03:58 PM
freeskier's Avatar
freeskier
i need to get to the wires attached to the cig lighter to gwt power for guages. how do i get the center console up? thanks
Old Aug 19, 2008 | 06:00 PM
MUShadd's Avatar
MUShadd
grab your shifter ring, and pull up, it simply pops off. then reach underneath the console to pop out the power mirror control...just push. once you have that out, remove the two screws that are under it. there are two more screws in each front cup holder. remove them. lastly, on each downtube there are two torx screws that you have to remove. once you've done all this, all the pieces are freed and you can gain access to your lighter.
Old Aug 20, 2008 | 01:11 AM
xnotfunkylex's Avatar
xnotfunkylex
^ That's the ticket.
Old Jan 2, 2009 | 01:02 PM
Amanda17's Avatar
Amanda17
About removing center console
How do you get the trim piece under the steering column off to get to the torx screws on that side?
thnx
Old Jan 2, 2009 | 01:17 PM
IrishCooper's Avatar
IrishCooper
PULL! lol
Old Jan 2, 2009 | 01:31 PM
Amanda17's Avatar
Amanda17
I never would have guessed! Too many times pull = Break.
Thnx
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
xraycat
Aug 12, 2015 02:36 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
