Interior/Exterior How about adding heated seats and auto climate control?
Old Dec 12, 2014 | 12:24 PM
  #26
AKIndiMini's Avatar
AKIndiMini
Originally Posted by climbingaggie03
...I curse it nearly every time I have to turn it on, especially if I need the defroster which apparently will only run on high fan speed...
I had the same problem with the auto climate control on my '04 R53. Turns out, if you push and hold the defrost button - the system will simply switch to moving the airflow to the defroster vents, but not run on full-speed crazy mode.
Old Dec 12, 2014 | 12:56 PM
  #27
ZippyNH's Avatar
ZippyNH
Originally Posted by BetaMini
So I bought an 05 R53. It has auto climate, but the **** is stuck. It doesn't move very freely at all. Think it'd be pretty simple to swap the entire module out from my 06?
You need two things...
A q-tip with a few drops of water, and some plastic safe contact cleaner...
Bet some soda/coffee splashed on the button...got it stuck...
Use the q-tip to get a couple drops of water behind the buttons...then wiggle it...
The use the tube on the contact cleaner to spray a bit behind the button...
Problem solved...
Pretty common...
You could spend $50-100 on a used part...but I bet you can fix it for $7...auger in soda and code that splashed from the cupholder does mess stuff up...
eatsleepautox
Oct 30, 2015 06:46 AM
bseiden
Aug 15, 2015 10:16 AM
ludedude
Aug 10, 2015 07:16 PM
2manyhobbies
Aug 9, 2015 06:02 PM
