Interior/Exterior DIY color line/ Schroth harness (pic)
Quick note guys,
I did talk with Matt from HMS at Watkins Glen at the end of August. He explained to me that the weak link is the testing company - there is somekind of bottleneck at that point. Since the belts have an impact on safety, they need to be certified before marketing. Let's put it this way: I'd rather wait for a tested product than some poorly designed belts that could impact my and my passenger's safety.
I gave up asking them. I'm going to wait until the start of the autox season next year and if they have them done by then, great. If not, I'm just going to modify the R53 version to make it work.
oh come on people. there is nothing different with these belts for the R56 than for the R53. The only modification is removing literally 1" of plastic on the side of the clip. NONE of the stuctural parts are affected. NONE of the metal clips are even touched. It is the exact same way it is mounted in the Gen 1 cars and those seem to be fine.
If you want the belts, get the belts, love the belts, thank me later.
Not saying any of that *will* happen but it is all a *risk*, so there's more to it than just filing (and weakening) a connector.
Everything I have heard so far seems to indicate that the stock seats have not been able to pass the test. So it's more of an issue with the seats not being able to handle the forces of a crash test with the harnesses' effect on them. That's a little concerning to me.
All in all, I'm probably going to get the R53 set and just use them for autox only anyways, not on the street where the crash safety really comes into play.
I’m kinda with Spdu4ia on this one.
The Quick-Fit Rallye 4 belt we’re talking about (and I assume the Pro version as well) is marketed as street legal. I, for one, wouldn’t EVER use it on the street. Aside from testing, airbag, etc. issues, if you’ve tried one you release it’s REALLY impossible to turn around and back up wearing one of these. Maybe you all can get everywhere without having to move around to look at things but I can’t. It’s a good idea for me precisely because you CAN take it out easily and NOT use it one the street.
The belt, if they ever design one for the R56, will probably be essentially the same. It’s the strength of the seat that they’re testing (maybe). My club already didn’t want them used on track, even with ones that were in R53s.
So for me, the only issue is autox. And I’m willing to take the risk (or I wouldn’t be doing autox....).
If it would be OK in HS class, I’d eventually delete the rear seats, add a roll cage, and get a real harness. But that’s in the way off future.
Rob
Rob
M7Speed
Aug 18, 2015 05:18 AM
