Interior/Exterior Factory Rear Fog light install kit.
Old Sep 23, 2003 | 04:36 PM
  #26
doomsdaybob's Avatar
doomsdaybob
but I am curious about whether or not the dealer really needs to activate the switch and if so would they entertain an alternate function?
>>Thanks
>>Chuck
That is something I wouldn't mind finding out also. If the the switch can be installed but wired for another function w/o the dealer getting involved I would be very happy. If not at least I could fill the empty position and have full house.
Old Sep 23, 2003 | 05:00 PM
  #27
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Unfortunately the dealer has to get invovled to activate the functioning of the switch. Once that is done, however, you can intercept the wiring running to the rear fog lights and use it instead for another function, say for rally lights or whatever.
I would use a relay activated by the fog light power if you plan on using this for any sort of high current draw because the rear fog lights are not that powerful and are wired and supplied as such.
Old Sep 24, 2003 | 08:25 AM
  #28
cdconsor's Avatar
cdconsor
Thanks for the definitive heads up on that one. Yeah I think a relay is in my future.
Old Sep 25, 2003 | 10:02 AM
  #29
rcase13's Avatar
rcase13
What exactly does the $75 rear fog light kit contain? Does it replace the missing toggle switch? Do we know this for sure?
Old Sep 25, 2003 | 10:04 AM
  #30
mbabischkin's Avatar
mbabischkin
The $75 is for the replacement switch bank. It's not just the missing toggle but the whole piece. That is from the announcement MINI made on its release....
Old Sep 25, 2003 | 10:19 AM
  #31
Greatbear's Avatar
Greatbear
Yes. The 'rear foglight only' kit only amounts to a switch panel that includes the rear fog toggle, everything else needed is already in the car. All that is needed beyond the switch panel is a recoding of the body control computer to activate the option.
The front kit comes with the lights, wiring, a switch panel, hardware, etc. Again, once that is installed the BC needs to be made aware of the new option.
I have the stuff on order and will take pictures of the contents and post when I get it so everyone knows what is included.
Be on the lookout for a how-to coming soon!
Old Sep 25, 2003 | 12:27 PM
  #32
rcase13's Avatar
rcase13
Wow a full toggle switch bank... Cool... I guess I get to keep the old bank?
Consider mine on order... Wait... I'll have to wait. My wife says no. I spent too much this week already...
Old Sep 25, 2003 | 01:27 PM
  #33
Super_MINI's Avatar
Super_MINI
If they are sending the entire switch bank, how do they know how many switches to include? Some cars have fog lights, some don't, some have DSC and some don't. I have one missing switch and I would expect that it was for the Fog lights.... would look nicer if there wasn't one missing.
Old Sep 25, 2003 | 01:28 PM
  #34
mbabischkin
Probably, if you have the dealer install the new switch bank you should be able to tell them you want the parts back.
I believe (and somebody with more knowledge out there can either correct me or confirm this) that it's actually the law. A mechanic's shop must return the old parts to you if you request them....
Old Sep 25, 2003 | 01:32 PM
  #35
Nuvolari's Avatar
Nuvolari
Everybody get's the switch in the DSC position. I have one. It is marked, "ASC" instead. It controls wheel spin. I turn it off right after I put the key in the ignition.
Old Sep 25, 2003 | 01:38 PM
  #36
Minibeast's Avatar
Minibeast
3 hours for install!! ???
Lets try 1 hour if you do it yourself and take to the dealer for the 15 minutes it takes for the computer to be updated. I have this on my car now (needs to be taken off actually). All you need is the star pattern bolt sockets ($10? from Home Depot) and your ready to do it yourself. Simple plug and play.
  #37
Greatbear's Avatar
Greatbear
As with any other laws, there ARE exceptions. You wont get your old parts back if they are replaced under a warranty or if the part you bought requires a core exchange. In the case of the latter, you can have your old part, but the replacement will be more expensive without the core return.
In the case of the switch bank, there is neither, so you should get your old part back, which I recommend. The switch being removed is perfectly good, and it's bought outright, not a remanufactured part that requires to old part as a core. The only reason why you'd have a tough time getting it back is if the installer (dealer in this case) wants the old switch set to use in another car as a replacement. You can simply accuse the dealer of installing used components and charging new component prices.
The old switch, even though it is lacking a toggle (or two), can be used later to fix the one now in the car if a toggle should break or act up.
Old Sep 29, 2003 | 08:25 PM
  #38
jojousa's Avatar
jojousa
I just outlined my idea of how this should be done in a post (Using rear foglamps as brakelamps.) a little while ago... just thought I'd let you all know in case you didn't see that thread.
Old Sep 30, 2003 | 01:55 PM
  #39
Greatbear's Avatar
Greatbear
Looks like I was one of the first who got the 'rear foglight kit'. Actually what I got was a front and rear foglight retrofit kit which includes lamps, wiring, relay, hardware and such to install the front lights, and the part that makes it a rear kit as well is simply a full bank of toggles.
First impressions: I received simply a box full of parts, no instructions whatsoever. Being that I more or less know what I am doing already, that shouldn't be too much of a problem. What I do notice is that I have received more 'stuff' than I actually need. Since the kit must cover all models and years, some of it has to be altered to work with my '03 MCS, which did not come with factory foglights, but already has the relay and fuse in place in the fuse/relay box. The wiring from the BC1 to the relay also seems to be in place already as well. The wiring harness that came with the lights will have to be slightly altered to remove that which is already there. I end up with some spare parts that might come in handy later.
The rear foglight portion of the kit as we all know is just the full bank of switches, once this is in place and the car recoded to make it 'aware' of the new options. I modded my brake lights already to include the fogs as part of the brake lights, but unlike most who have used a wiring modification or jumper, I used two diodes soldered into the bulb holder assemblies. This will allow the fogs to operate independently of the brake lights, but allow the brake lights to always light the upper part of the taillamp (the foglights), the best of both worlds.
My install experiences and pics coming soon!
Old Sep 30, 2003 | 04:44 PM
  #40
wagsFTB's Avatar
wagsFTB
sounds like something that might pose difficulties for someone who more or less DOESN'T know what he's doing, to which he'll have to pay service countless dollars to do instead... look foward to pics and further instructions
- wags
Old Sep 30, 2003 | 04:52 PM
  #41
cdconsor's Avatar
cdconsor
Great work there. Really looking forward to your pics and hopefully something like a how-to (pretty please )
Old Sep 30, 2003 | 08:45 PM
  #42
jojousa's Avatar
jojousa
Would it cause a problem to have both the fog light power and the brake light power going into the fogs at the same time? It seems to me that there would be too much voltage going in, but I can see how it would be ok... The lights would only draw the required current, even if twice the current was offered and the voltage, though coming from two different wires is still coming from the same battery. If that's the way it is (anyone know for sure about that?), the relay thing isn't needed and your diode idea would be much simpler... nice work :smile:
Old Oct 1, 2003 | 10:08 AM
  #43
Greatbear's Avatar
Greatbear
HERE is the little write-up I did for the 'diode mod' complete with pics. I hope it makes sense to most people.
As for problems with applying too much current to the foglight bulb, this is not an issue because the bulb itself determines the current draw, you are simply applying the voltage (which remains the constant 12-14.5 volts of the entire electrical system) from multiple points. The current draw will be simply shared by these points.
Old Oct 1, 2003 | 05:16 PM
  #44
jojousa's Avatar
jojousa
Thought so, after I got to thinking about it more I realized this, but needed someone else to say it was so... thanks for the clarification on that :smile:
Old Oct 1, 2003 | 09:34 PM
  #45
rrypma's Avatar
rrypma
That's strange. I don't have a DSC switch so I'm missing 2 switches. I'm wondering with the new bank, I wouldn't be able to have the DSC activated. Perhaps additional hardware would be required? ASC, I was told, is standard on every MINI. Mine is an 04 though, so they may have taken away the ability to turn the ASC off.
Old Oct 2, 2003 | 01:22 PM
  #46
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I'm in a similar situation. 2 missing toggles. Hmmm...if I tell them that I have a loaded car when I order, maybe I can get a full bank of toggles and use the spares for something else?
Old Oct 2, 2003 | 01:31 PM
  #47
cdconsor's Avatar
cdconsor
I think so. I got mine from CAC and was asked if I have fog lights and DSC, presumably so they could send me the correct set of switches. No reason you couldn't say the same thing.
Old Oct 2, 2003 | 09:36 PM
  #48
blacknblue's Avatar
blacknblue
Photographer / Beer Dude
Got the rear fogs this a.m. Already had the front fogs so it was $75 with half hour labor. Came out to $129.
I'll post pics and more info on my weblog tomorrow.
Old Oct 11, 2003 | 02:46 PM
  #49
Bound4NW's Avatar
Bound4NW
Greatbear - thanks for the directions.
Installation of the switch panel took about 20 minutes and went without a hitch. Even the wife (who owns the car) approved of my work. LOL
Now to the dealership for the programming and then the diode install for both operations.
Old Oct 13, 2003 | 09:10 PM
  #50
wagsFTB's Avatar
wagsFTB
nice, i should be getting the toggle panel in this week, and was wondering if you could tell me your dealer experience when you take it in to get reprogrammed. I'm wondering if i can just pop by and get them to do it real quick, as i don't think it takes but a minute. also let us know what they charged.. i'm hoping it shouldn't be much at all, if anything.
thanks
- wags
