Interior/Exterior Front grill minimum % open
Old Apr 22, 2008 | 08:36 AM
Roadsailer's Avatar
Roadsailer
I want to use some new material for the front grilles, but need some advice as to the minimum percentage needs to be open to the airflow. The last thing that I want to do is to starve the engine of air for cooling and/or breathing. My intention is to leave the intake pretty much completely open, but wondered just how restrictive the airflow can be before causing a problem for cooling.
If I can't get the airflow through the front, I might consider ducting it in from the bottom or through the hood.
Paul
Old Apr 24, 2008 | 05:01 PM
second to none's Avatar
second to none
what exactly are you trying to do?
also don't forget the grille in the bumper takes in a large volume of air as well.
Old Apr 29, 2008 | 04:31 AM
Roadsailer's Avatar
Roadsailer
I am trying to replace the grille with a custom made one ... just need some idea of the flow rate required i.e. the open area of the mesh
Paul
Old Apr 30, 2008 | 10:34 AM
RussellCory's Avatar
RussellCory
Paul
You've got a good question there. Best way to figure that out would be to first figure the total square inches of the grill opening. Then figure the square inches blocked by the grill slats & the backing plastic. Divide figure 1 by figure 2 and you're the man…
boostedhaze
Jan 2, 2018 07:26 PM
wkp1219
Nov 13, 2015 07:52 AM
dcrna1
Aug 19, 2015 01:30 PM
FLYM1N1
Aug 15, 2015 11:20 AM
