Interior/Exterior DIY splitter update... almost done.
Old May 25, 2008 | 10:39 AM
  #26
emsjr's Avatar
emsjr
Finally everything buttoned up..
Well, work slowed down for a couple of days, so I finally got the splitter attached to the chin, all installed. Everything went smooth except the folks in England managed to cross thread one of the 6X100 bolts that attach the lower chin to the splash shield, so after getting a couple of new ones, it was full steam ahead. I like the looks without the stand-offs, but that's just me, many of the other DIY splitters look good as well.
Attached Thumbnails DIY splitter update... almost done.-splitter-on-car.jpg   DIY splitter update... almost done.-splitter-on-car-b.jpg   DIY splitter update... almost done.-splitter-on-car-c.jpg
Old May 25, 2008 | 11:37 AM
  #27
cartar452's Avatar
cartar452
Looks Great! diy splitter ftw
Old Oct 22, 2008 | 02:18 AM
  #28
MC 2's Avatar
MC 2
Hi i im working on something new for the spliter i will cut it out of 1/4 black lexan..i be posting picture wen finish..
MC 2
Old Oct 22, 2008 | 11:15 AM
  #29
Eurothrasher's Avatar
Eurothrasher
What Thickness do you recommend
I went to Eplastics site, and see they offer various thickness of ABS, but could not find a sheet at 60", so would have to go with 72".
And for those whom have a white MINI, or want contrast to match mirrors and roof ~ they offer the ABS plastic sheets in white as well
They can also pre-cut sheets into 12"x5' strips and ship cheaper that way.
What thickness do you recommend for this application emsjr ? 1/8 or 1/4 inch ?
.250" x 48" x 72" Black Sheet
.250" x 48" x 72" Black ABS Haircell Finish 1 Side
Quantity
1 – 3 sheets @ $128.164
or
.187" x 48" x 72" Black Sheet
.187" x 48" x 72" Black ABS Haircell Finish 1 Side
1 – 3 sheets @ $96.154
Old Oct 22, 2008 | 06:22 PM
  #30
emsjr's Avatar
emsjr
Well here's what I did..
Because of the five "wedges" I made which I glued to the splitter, then carefully drilled and screwed into the OEM "chin", I used the 1/8" thickness. I wanted it to look as stock as possible. It is well supported and I have had the MINI over 100 mph with no issues what-so-ever. If you are not going to do the wedges and the bolting to the five existing holes, I would go with the thicker 1/4" piece. There is a total of 10 stainless bolts and fender washers (through the wedges) and the stock mounting holes keeping it solid on mine. It's a bit tedious getting the wedge shape perfect so the ABS thin glue will work, but I'm that ****, many wouldn't be.
The thicker splitter with the external supports would be easier, but not the look I wanted. I also used two way tape to adhere 5 pieces of the ABS to the bottom as "rub" blocks, which I have not hit yet, (Mini is not lowered.)
Hope this all helps,
Gene
P.s I went with the 72" piece.
Old Oct 23, 2008 | 05:35 AM
  #31
MC 2's Avatar
MC 2
Quantity
or
HI check if they have white lexan and for the the thicknes i sujest 1/4''
honderpilot
Nov 30, 2023 10:56 AM
NorthWestEuro
Oct 21, 2015 08:11 PM
M7Speed
Oct 1, 2015 07:05 AM
whowantstorace
Sep 27, 2015 06:16 PM
LAcooper
Sep 22, 2015 10:03 PM
