Interior/Exterior splitter material
Old Mar 25, 2008 | 02:12 PM
freeskier's Avatar
freeskier
splitter material
making my own front splitter and was wondering what was a good final buld material. i like how the Wyvern splitter looks, any idea what its made of? thanks
Old Mar 25, 2008 | 02:26 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
The Wyverns' are very competitively priced...the splitter costs more than the wing for many reasons...the wing is a helluva deal compared to all the other extensions and wings...
Old Mar 25, 2008 | 02:36 PM
freeskier's Avatar
freeskier
i like the wing alot and understand that its reasonably priced but WHAT IS IT MADE OF??
Old Mar 25, 2008 | 03:52 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
You will have to PM COR BLMY...sorry man.
Old Mar 26, 2008 | 07:39 AM
freeskier's Avatar
freeskier
nobody? im thinking some sort of ABS or really durable plastic. any idea who carries it?
Old Mar 26, 2008 | 08:51 AM
Wake|MCS's Avatar
Wake|MCS
Carbon Fiber maybe? Or Carbon Kevlar? ABS would be good too, less fear of the splitter cracking from scraping the ground.
Question, what kind of splitter are you after? Something like the Hamann or more like the m7?
Old Mar 26, 2008 | 08:56 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I think ABS would be pretty good and you can get it for nice and cheap. Most of the ones available from MINI vendors are fiberglass with a CF layer on top...not sure about the wyvern one though....never seen it in person.
For a DIY project ABS would probably be the easiest to work with and most cost effective.
For ABS plastic check out http://www.mcmaster.com/ under 'raw materials' they have all sorts of stuff from ABS sheets to CF sheets. You pick the thickness and dimensions so you can really find exactly what you're looking for.
Old Mar 26, 2008 | 01:14 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
McMaster is a great site I am looking into their Al and(or) CF for a homegrown diffuser
Old Mar 26, 2008 | 01:52 PM
Rally@StanceDesign
They've got a big warehouse only 5 minutes from my house too So many cool options for those fun DIY projects
Old Mar 26, 2008 | 03:02 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Nice to know
Old Mar 26, 2008 | 03:33 PM
freeskier's Avatar
freeskier
it will looke like the M7 splitter, i have already found the turnbuckles and im pretty sure im going to go with ABS. and recomendadtions on thickness?
Old Mar 26, 2008 | 05:09 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
1/8" or 3/16" no thicker, no thinner
I think that 1/16" would be too flimsy and 1/4" would be too thick...but if you wanted the extreme thinness and thickness would be those
Old Mar 26, 2008 | 07:35 PM
L1LABRAT's Avatar
L1LABRAT
Personally, I think any thickness of ABS would be too flimsy.JMHO There are reasons why they arent produced in that material. there are a lot of aerodynamic forces put on any near horizontal surface when speeds get over 20 mph. Think about holding your hand out the window and how much the wind force moves it up or down when you turn it slightly. Now multiply that surface area times twenty.
Old Mar 27, 2008 | 02:52 AM
meh's Avatar
meh
Aluminum will work; I have a friend that used it on the front (and sides) of his Viper.
Old Mar 27, 2008 | 05:43 AM
freeskier's Avatar
freeskier
friends with honda have front lips made of urithane, would that work or would a thicker piece of ABS be better
Old Mar 27, 2008 | 07:01 AM
Fatherdeth's Avatar
Fatherdeth
Urethane wouldn't be bad, but you would want to put a a couple of layers of fiberglass on it for stiffness.
Old Mar 27, 2008 | 09:53 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
^then, couldn't you do the same if the ABS was too flimsy???
Old Mar 27, 2008 | 10:45 AM
L1LABRAT's Avatar
L1LABRAT
yes
Old Mar 27, 2008 | 01:26 PM
freeskier's Avatar
freeskier
so im thinking i will pick up a sheet of ABS and if it is too flimsy i will reinforce it with some fiberglass
Old Mar 27, 2008 | 01:43 PM
Fatherdeth's Avatar
Fatherdeth
You can use fiberglass on any material to include plywood, cardboard, etc. So you will be safe witht he ABS. As a matter of fact, the ABS would be the best material to use. Fiberglass can be messy and smelly, so make sure you use gloves and work in a ventilated area. You can use fibercloth and lay liquid resin over it. Then you can sand it and paint it. It sounds easier than it is, but not at all hard. Just time consuming.
Filmy
15
Jun 6, 2023 06:27 AM
Joeygonz
Oct 2, 2015 11:24 AM
gnhovis
Sep 28, 2015 04:07 AM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
