Interior/Exterior DIY Blackout
Old Mar 8, 2008 | 09:43 AM
corin.mcblide's Avatar
corin.mcblide
DIY Blackout
The chrome is really starting to tick me off. I wanted to buy the whole blackout stuff from lyle's but it started to look like a bit too much just to blackout my MC. So i was thinking....what if i just took off the parts, sanded them and painted them with some krylon and gave em a nice clear coat? Id like to hear all of your opinions on this matter. Any suggestions/grips/complaints/constructive criticism etc. i am open to anything you want to throw at me
Old Mar 8, 2008 | 11:03 AM
glnr13's Avatar
glnr13
the vinyl lasts longer and is less prone to chips.
but i did do a few blackouts myself using some rustoleum satin black without clear coat
Old Mar 8, 2008 | 01:45 PM
VicSkimmr's Avatar
VicSkimmr
I'd go vinyl, it won't chip like paint will.
Old Mar 10, 2008 | 04:45 PM
Spdu4ia's Avatar
Spdu4ia
Go with a paint called "plasitdip" it comes in a yellow can and you get it at Lowes or Home Depot. It will not be shiney though. It is a rubberized coating and does not require clearcoating and resists chipping really well.
Old Mar 10, 2008 | 05:27 PM
ColinMc's Avatar
ColinMc
Small parts are easy...i'm thinking of offering a professional painting service for trim pieces but would have to gauge interest first. Not sure where to start a thread asking? Paint and body stuff is a hobby of mine, mainly bike stuff but i'm slowly getting involved in Mini stuff now that I own my own lol. Painting my arches soon, and blacking out my own trim as well. I'll have to start a thread to see if anyone is interested. If I do things in batches it'll bring costs down. I can do anything from completely flat finishes, to full gloss, black or any factory color or anything really...you name it. Even the dreaded Joey Mod.
EDIT: If you do it yourself, make sure you clean those pieces REALLY well, scuff them with 600 grit or so to roughen up the surface, then hit them with a good primer, then color, then clear them. Even if you are using aerosol paint it should come out halfway decent.
Old Mar 10, 2008 | 06:09 PM
ghosthound's Avatar
ghosthound
not only that, but if you put on a thick enough coating, it will be really easy to peel off in 1 piece if you dont like it and it wont leave any residue.
I would say that plastic-dip is even more chip resistant than vinyl.
Old Mar 25, 2008 | 08:05 PM
checkercoop's Avatar
checkercoop
I say go for the spray paint...i did mine because I figured it was worth the try and if it came out horrible, then I could spend the money. Its very easy, satisfying, cheap, and easy to touch up if need (which I havn't had to do and I've had my stuff painted for about 3 months now and plenty of highway driving)
1. I grinded the pieces just to deshinny the chrome
2. Then used an automotive primer
3. Then Krylon Fusion for plastic
4. and finally a triple thick clear coat
It came out great and sure was cheap. I've gone on to paint my exhaust tip black with 1200 degree engine paint. Holds up amazing. Over the summer I gotta hit the muffler because that can still be seen...possible the control arms too.
I like self painting sooo much that this summer I'm going all out and painting my rims
Old Mar 25, 2008 | 08:41 PM
corin.mcblide
hey thanks for the info. really helpful
what did you use to deshiny the parts?
Old Mar 25, 2008 | 09:25 PM
checkercoop
Sandpaper. I used about 150-200 grit...anything less just roughed up the surface too much and anything more made it a lot more work.
Goodluck, and get a spay can gun adaptor. I did all mine without one and my fingers were sooooo sore after because those spray nozzles put a lot of strain on your fingers. I just got one (haven't used yet, but only $3 and fits any can and lifetime warrantee haha) to use for the rim project
Old Apr 1, 2008 | 02:16 PM
100percentcotton's Avatar
100percentcotton
Just painted my rims black (no pics yet though, camera is broken) using spray paint and they came out awesome. Sanded with 150 grit first then 400. 1 coat primer, 4 coats semi-gloss black (wet sanded inbetween), and 3 coats of clear. Took a whole day, but it was worth it.
Old Apr 1, 2008 | 02:54 PM
corin.mcblide
hey checkercoop what clear did you use?
Old Apr 1, 2008 | 08:52 PM
checkercoop
Krylon Triple Thick Clear Coat...i found all my paints at walmart it works well, and it like 3 coats with 1 spray (so surely I still did about 3 coats of this so I virtually have 9 coats haha
M7Speed
Oct 1, 2015 07:05 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
whowantstorace
Sep 27, 2015 06:16 PM
